Thread: First test with the TF-100 no chlorine!
    Jan 2015
    San Jose, CA
    237
    Got my package and the first impression when I opened the package was WOW I'm overwhelmed just looking at all the included stuff, but I like...
    Actually that wasn't the reason for this post, I tested CYA and got about 35, then I went on to test for Chlorine.
    Added 10ml of pool water, added a heaping scoop of the powder, swirled and watched it. It stayed clear. Just making sure I'm doing this right.
    4 days ago, I tested my water and my FC was at 3. I've had the solar blanket over for the past 2 days and temperature has been about 67 degrees.
    If my CYA is right, what's eating up my chlorine so quickly?
    I'm getting ready to slam the pool so I gotta make sure I'm using this kit properly.
    SF Bay
    ********20,000 gallon IG Fiberglass, DE Filter, Hayward Max-Flo VS, Taylor TF-100 Test, Circupool RJ-45********
    38,507
    Re: First test with the TF-100 no chlorine!
    Sounds like 0 FC in the water if you never saw a hint of pink.
    It is normal to lose 2-4ppm of FC every day .. this is why you need to test and add bleach every day.
