Thread: Over night chlorine lost test question
    Oct 2013
    Los Angeles, CA
    87
    Am working graveyard shift now and there is no way I can make it hone before Sun raise to test for lost chlorine. What are my options? Can I have some one Take a sample from the pool before Sun raise and save for me until I get home to test it ?
    Intex 12 by 24, Intex 2600 sand filter (soon to upgrade), deck under construction
    Re: Over night chlorine lost test question
    No, that won't work. The FC level changes when the sample is removed from the pool. FC and PH always need to be tested directly after taking the sample from the pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    I'd suggest you just teach someone else in the house how to run the test. My guess is that just about anyone over the age of ten could get the sample to the right marking on the vial and count the drops and be able to differentiate between pink and clear.
    Oct 2013
    Los Angeles, CA
    87
    Thank you for the replys I will teach some one else
