Results 1 to 7 of 7
Thread: Waterfall help
    May 2014
    san antonio
    3
    Exclamation Waterfall help
    5 years ago we installed a pool with an 8 foot wide, four foot high waterfall. although beautiful, we rarely turn in on because it is so very loud. We have turn the pressure down at the pump, but the pump sounds like it is really struggling. What is a solution so we can have the waterfall running softly when we are in the back yard? Should we install a smaller pump?
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Waterfall help
    Exactly how did you turn the pressure down on the pump?
    Mark
    Feb 2014
    Upstate, NY
    390
    Re: Waterfall help
    What kind of pump is it ?? VS ??
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Azmp1's Avatar
    Jul 2012
    Maryland
    284
    Re: Waterfall help
    I have the same issue with my sheer descent. It about 4' high and is loud... My problem though is the height drop of the water. So, when you're saying your waterfall is 4', are you talking about the drop of the water, or the overall height of the waterfall, as an stone with water just going down the stone?
    32000gl freeform gunite/diamondbrite perl pool || Jandy Sheer Descents || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS6 w/Aqualink touch || Jandy iAqualink2.0 || Pentair Intellibright LEDs || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 140k BTU heat pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Waterfall help
    To reduce flow through a pump you you have to valve it down on the output side, NOT the suction side. Turning down water flow into a pump will starve the pump for water, make noise and ultimately damage the pump.
    May 2014
    san antonio
    3
    Re: Waterfall help
    I tuned it down on the output valve and it worked! Thanks
    DFW, TX
    24,513
    Re: Waterfall help
    Right on!
