Results 1 to 7 of 7
Thread: My First Open
    acgibson's Avatar
    Aug 2014
    Olney / IL
    61
    My First Open
    Ok, I opened my pool for the first time yesterday. It was clear with only a few leaves, cypress needles, and about 20 crawdads scattered on bottom. There was no visible signs of algae.
    Readings after I added water and pump ran for couple hours (7 P.M.)
    6.8 FC (I added about 50oz in skimmer when I first fired up pump)
    0.0 CC
    7.5 pH
    110 TA
    270CH
    25-30 CYA
    30 Borate
    3350 Salt (according to SWG)
    water temp was 56 at open
    OCLT 12hrs (7 A.M.) with cover on all night (SWG unplugged):
    Water Temp 67
    6.6 FC
    0.0 CC
    7.5 pH
    110 TA
    270 CH
    25-30 CYA
    So does this mean I made it through winter without issues in the Water (other than running jets to bring TA down a little)?
    One thing I am wondering is why my CYA went down over the winter it was around 50-60 when closed? I know I added about 6" of water that would dilute it a little when I opened, but I didn't expect it to be cut in half. Does water temp or something consume it or mess with test? Pool Math called for 110 oz to get it to 70, but I only added 32oz in skimmer basket to start incase the readings were off and I checked here.
    18,900gal Viking 16'x40' Fiberglass In-Ground Pool w/ Cover Pool Auto Cover.
    WhisperFlo WF-24; Clean & Clear RP 150 Cartridge Filter; UltraTemp Heat Pump; IntelliChlor IC40 w/ IntelliPh Acid Pump;
    Easytouch Panel w/Screen Logic. Kreepy Krauly 820 Robot.
    LaMotte WaterLink Mobile Spin Lab & TF100/K2006 w/ Speed Stir.
    Re: My First Open
    It is not uncommon to lose some CYA over the winter. If only we could get that to happen on purpose.
    acgibson's Avatar
    Aug 2014
    Olney / IL
    61
    Re: My First Open
    Is the first day too soon to do a oclt? Is another one needed in a few days when water is warmer?
    Re: My First Open
    You are much more likely to fail an OCLT the first night, but having passed you should be fine.
    acgibson's Avatar
    Aug 2014
    Olney / IL
    61
    Re: My First Open
    I only lost another 0.2 FC in 24hrs with no chlorine additions (cover was on entire time). All other readings stayed same.
    Thanks Jason
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: My First Open
    Hey AC,
    May I suggest using a 10ml sample size for FC? Entirely up to you, but it will save you some Titrating reagent.
    Essential Links:
    acgibson's Avatar
    Aug 2014
    Olney / IL
    61
    Re: My First Open
    Thanks Patrick, yeah I usually do but for the opening and OCLT'S I used the 25mL for the accuracy.
