Results 1 to 8 of 8
Thread: Filling pool with hot water?
    Oct 2014
    Bay Area, California
    146
    My pool is being refinished starting in may, meaning in june I will be set to be filling it back up. I have no pool heater, but I do have a tankless hot water heater.
    Using the calculator here: http://www.zodiacpoolsystems.com/Ene...ater-Cost.aspx , I found that it would only cost around $50 bucks to fill the pool with 80 degree water, instead of the 55 degree ground water.
    Has anyone ever done this? I feel like running my hot water heater for a couple days straight will probably **** it out. Right now just with a cover the pool is about 70, I will be installing some solar panels too but I cant fit as much as I will like, probably about 75% of the pool sqft.
    I am just concerned that it may take a month or more to get the water up to a decent temp, by which time it will already be the end of june, but I do know that when the water is cold I will get quite a bit of heat gain per day due to the temperature differential.
    Approx 15,000 gallon gunite pool, fiberglass finish. Hayward SP2302VSP, compools solar controller, 6 4x10 "Sealed Air" brand solar panels, Clean and Clear 520 cartridge filter
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Filling pool with hot water?
    Those units are not designed to be used like this. You will be running it for hours and hours and could potentially ruin the unit. It isn't advisable to do this.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Oct 2014
    146
    Yeah that's kind of what I was thinking. My birthday is june 6th, so much for a pool party
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    My kids were in our 64 degree pool yesterday, so the party is possible, but not for the faint of heart.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jun 2012
    western NY
    1,560
    Even if you could do this, the water will cool down to roughly the ambient air temp or to the lowest overnight temps in a couple of days
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Mar 2011
    441
    I have seen hydronic heating guys use tankless heaters to run heat in a house during contstruction untill the boiler system is installed. They run these heaters for years, and they almost never turn off. I am not sure why it would ruin it, but if you are in a area of high calcium you may need to descale it when you are done.
    Many health clubs use standard tankless units and they run for hours on end.
    20X40 30,000 gallon gunite pool
    Oct 2014
    146
    Quote Originally Posted by danpik View Post
    ha, you need to rethink this. Right now the pool is 71, and we have been getting temps down in the 40's
    Jun 2012
    western NY
    1,560
    Quote Originally Posted by Nickmpower View Post
    OK, then it will cool down to 71 deg in a couple of days. The ground temp and the daytime temps in your area is probably what is helping keep it that warm. Heat loss is a function of evaporation for the most part. Conduction thru the ground is the other component. If the daytime temps are higher than the pool temp the heat loss will not happen. (you will have gain) However, if the overnight (cooler) temps are lower than the pool water temp then the evaporation will be higher and more heat loss will occur. This is why solar covers are good at keeping heat in a pool over night. It slows the evaporation process and the air pockets provide a small amount of insulation value. Once the ground temp around the pool gets up to the temp of the water thru conduction, the "heat sink" ability of the ground will also help stabilize the water temp
