Thread: Cold Water Temps and False Salt Rerading
    May 2008
    Louisville,KY
    59
    I have the Circupool si-45+ and when I fired it up for the first time this year it ran for a few minutes and immediately went into a low salt, check cell mode. My water temp here in Louisville is only about 61 degrees according to the Circupool readout. This unit continously shows the salinity on the readout. It says 3000 ppm. You can scroll through the menu and get a instant readout of the current salt level. The readout on there shows 0000. I tested my salt level with a test kit and it showed 1400 ppm. I am curious if the low temp of the water has any bearing on the actual level of the measuring of salt in the pool. I closed last year at 3000 ppm. Unit was installed last July and performed flawlessly through the rest of the season. Did not do any significant draining of the pool during the winter. The check cell readout has a feature where it flashes every 3 months for inspection. It currently shows a solid light. The current levels show the unit is not producing chlorine, which is normal based on the current salt level.
    16x32 IG vinyl
    24000 gallons
    Hayward super pump 1.5HP
    Hayward Pro Series Filter S244T
    3 returns, bottom drain, skimmer
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Cold Water Temps and False Salt Rerading
    Yes, low water temp has caused my SWCG to give false low salt errors and false low flow errors. It is supposed to be OK above 60, but mine isn't really consistent until mid-upper 60s. I use bleach until all my lights stay green and my FC starts to rise consistently over several days to a week. Two years ago I put WAY too much salt in my pool trying to correct the low salt error.
    If you are confident in the 3000ppm number then add enough to bring it to 3400 or so. Give it a day or two to fully dissolve.
    Jun 2014
    Roseville, CA
    343
    I think 3000 is the default on the screen when the unit is "off".
    As you push the button and scroll through the various readings, the reading at the end is the accurate one. After that the default reading in the window is an average. 1400 is way too low to generate, and maybe so low it's 0000 as far as detection goes.
    Also, if you are in generating range you should see your voltage climbing up and stabilizing around 26 volts if your salt is a bit low but "doable".
    My guess is that you'd be safe with starting with four 60 lb bags of salt to see where you end up. NOTE: to be on the safe side, shut off the generator when you add this much salt.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    May 2008
    Louisville,KY
    59
    The Swg is powered by a timer that also powers my pump. If I turn all the settings down to 0 and turn off the Superchlor switch is this the same as turning off unit. The power light is always illuminated when timer is activated.
    16x32 IG vinyl
    24000 gallons
    Jun 2011
    Long Beach, CA
    2,781
    Quote Originally Posted by tnewton7 View Post
    Yes.
