Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Does the concrete truck cause damage to your driveway?
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Hey guys - I have a pretty long driveway - nice concrete with no cracks I started thinking about how they access your backyard. I assume it will be okay for them to drive heavy equipment up my driveway? Right? Or will a concrete truck crack it? Any experience? I think I am over-thinking everything, but figured I would ask you guys . . .
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
    Aug 2014
    Shallotte, NC
    693
    Re: Does the concrete truck cause damage to your driveway?
    Don't know what the project is, but I wouldn't allow a full size concrete mixer on a typical 3 1/2 inch thick concrete drive. A concrete truck could absolutely crack it....
    If enough yardage is required, I would think they would be considering pumping the concrete, anyway....
    If the driveway is 4'' (3 1/2 as ewkearns correctly pointed out) thick, it will support the weight of a normal car or pickup with relative ease. A dump truck or concrete truck... maybe... but that's a big maybe. It would depend upon the grade of concrete, rebar vs mesh, and probably a hundred other things I'm not even considering.
    Were it my driveway I would say no. As ewkearns said a pump truck or maybe a conveyor (like this monster) or get the local highschool/college football team and a bunch of wheelbarrows
    14,000 Gal IG Pool/500 Gal Attached Spa
    Pentair Whisperflow 1hp Single Speed Pump
    Sta-Rite Posi-Flo PTM-135 Cartridge Filter
    Hayward H400 Natural Gas Heater
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes it could. They are extremely heavy.
    Essential Links:
    Golderdog's Avatar
    Feb 2015
    DFW
    61
    Quote Originally Posted by Sunbaby View Post
    Sun: I wouldn't allow it either. We did, and I truly regret that decision. We now have a crack.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    sounds like you should consider getting a pumper truck. How long is it from where the truck can come safely to where you need it placed ??
    Solar Blanket, Well Water, Borax Added. 68
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    And if you have any irrigation pipes under the driveway, .... a concrete truck will crack the drive without a doubt and possibly break the irrigation pipes under it.
    A pumper truck or a motorized concrete buggy are the best options. Check on pricing and availability of a pumper truck. Those can get really pricey, depending on how far it is from the truck to the pool. The motorized buggies may be the most cost effective, but you'll have to check.
    Divin Dave,
    They used the motorized buggies for mine. I do not recall there being an extra cost for the buggies, but the pumper was going to add about an extra grand for mine. They laid down plywood the whole way to the back yard so as not to damage the grass. Pretty cool to see how good they were driving them
    Steve ~16K IG Vinyl Pool, Hayward TriStar 1.5 hp, Hayward S244TE filter, Polaris 280 w/booster pump, Prologic PL-P-4, Hayward AquaConnect, 3 PAL LED lights, 3 Deck Jets, AquaComfort ACT 1100 heater and TF-100 Test Kit with SpeedStir.
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    So I am not good with distance - but it seems pretty long as far as driveways in a subdivision go. I will have to go measure the concrete to see how thick it is. Is there a way to tell if there is rebar or mesh in the concrete? Here is a pic of the driveway. I asked a couple neighbors that had pools put in - and they said the pool co drove all the way up on the drive with no problem - but I am a worrier. I guess I need to ask my PB - I am looking on the contract and I don't see anything about it . . .House.jpg
    ~Wendy
    Sep 2014
    North DFW
    161
    I would not take the chance. An excavator cracked the corner of our driveway, which had rebar.
    39' x 18' IG 3.5X4.5X9 34k gallon w/ raised spa, 3 stone scupers
    Jandy 60 SqFt DE, Jandy PDA PS6, Jandy JXi400 heater, Jandy 2.0 EPump w/SVRS
    A&A Manufacturing ICS w/G4 venturi heads
    2 incandescent lights in pool, 1 in spa.
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    The gunite truck should park in the street and pump the gunite through a hose. You driveway may sustain light damage during the dig phase when the bobcat or other diggin machine is travelling back and forth with payloads of dirt to haul away. Our dig was at least 100+ trips from the backyard to the front.
    The damage if any is really minimal. I noticed some small cracks on my driveway but nothing crazy, hardly noticeable.
    Your backyard will look as if a bomb went off at least for a couple of months. We went through an emotional rollercoaster happy, sad, frustrated, worried.
    In the end it will all work out and you will be happy you built a pool!!
    Completed 38'X21' IG Free form pool approx 18.5K gallons, sports pool w/spa and tanning shelf 3.5-5.5 ft. Jandy Cartridge Filter, Jandy stealth pumps, Jandy LXi Heater, I aqualink, Inline chlorinator. Click to see My Pool Build
    Mar 2015
    South
    18
    My PB specifically advised against having the concrete truck drive on our driveway or in our yard. I think it added $500 to our contract to use the pumper truck for the concrete decking.
    16x24 shotcrete pool with plaster; ~ 11,000 gallons; Hayward MaxFlo XL 1 hp pump; Hayward Pro-Series Top Mount Sand Filter; Hayward Turbocell SWG; Hayward ColorLogic LED light; Hayward AquaPlus Automation Panel; TF 100 Kit
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Thank you guys! I just sent a message to the PB to ask how they do it - and if I have to - I will pay more to have them stay off of it. So MUCH to learn!
    ~Wendy
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,432
    But, but, but you have us to help you! So all is GOOD!
    Kim
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    For REAL! This site is an obsession for me now!!!
    ~Wendy
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    do not allow a truck on that long driveway, you will regret it! A pumper truck is the way to go for sure!
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
    It was a $1400 up charge for me to do a "shuttle dig". The heavy trucks can crack your driveway usually along the edge where they exit/enter.
    Building: 30'x15' freeform w/spa and waterfall, 16k gallons, AA Quikclean in-floor cleaner and Quikskim, Pentair Easytouch 8 w/IC40 SWG, Intellabrite lights and bubbler, Sta-rite Intellipro VS, Sta-rite 2HP Waterfall pump, Sta-rite 400k gas Heater
    Jul 2014
    Independence, KY
    220
    Not a chance you should let the concrete truck on your driveway. Like was said earlier, if gunite, it will be hose pumped from the road. For the concrete for the patio around the pool (assuming you are not using stone or pavers) most likely they will just use a bobcat's bucket to drive the concrete back and forth. The bobcat or buggy will damage your yard, but that is much easier to fix than cracked concrete.
    IG W/Vinyl Liner Oval 18x40, 21K gal, Oval 3'-8'
    Pentair Intelliflo VS Pump, Sand Filter
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    They should be able to pump that from the street through a hose. Don't see any reason why they would have to get any closer.
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
  20. Back To Top    #20
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    During the dig the bobcat will create a path of dirt from the hole site to the awaiting dump truck, the dirt road will help minimize the damage to the drive way, also the bobcat should have this rubberized tracks vs. steel tracks.
