Results 1 to 11 of 11
Thread: Deck jets just installed - uneven pressure!
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    Just installed four deck jets. They are plumbed in pairs. So, there are two lines of coming from the pump, and each splits into two lines with a "T" before making their way to the deck jets.
    The problem is that one of the deck jets has about 20% less pressure/force than the other 3. I already checked and there doesn't seem to be anything (at least visibly) clogging the line. Any idea of how to fix this short of replumbing?
    12' X 25' in-ground. Hayward EcoStar Pump, Hayward DE 3620 Filter, Hayward Pro-Logic PS4 with Aqua Connect for automation, Hayward ColorLogic Led lights, Silencer Blower, Four Jandy DeckJets, Salt Pool, Neverlube Valves with One Actuator. Built by owner.
    Re: Deck jets just installed - uneven pressure!
    Deck jets are normally installed with individual adjustment valves for exactly this reason. Sometimes those valves are back at the equipment pad, often they are buried right next to the jet, as it is pretty much an adjust once and then bury kind of thing.
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    Well mine was plumbed in pairs. So I cannot adjust only the one I need adjusting. Essentially I can see myself installing a mini valve right at the deck jets to essentially reduce the flow of the others and bring them down to the one with the fewest pressure. However, that's seems like it would be counterproductive, since then to get the pressure where I want it I would have to increase pump speed past 2400 rpm.
    If no idea idea comes up, it will just stay as is.
    Apr 2015
    Camarillo, CA
    38
    I have recently installed laminar deck jets and the installation manual calls for valves at each jet to control the flow. It would be almost impossible to plumb 4 jets to have exactly the same pressure without a control valve of some kind. Since you know which is the weak jet, you don't need a flow control valve on that circuit. It may not take much more pressure to even out the flow. How do you know the RPMs necessary to have even flow?
    April 1, 2015 first fill of infinity edge of about 15,000 gallons. Aqua Blue Pebble Sheen, iAquaLink, Jandy 2 HP variable filter pump, Jandy 2.5 HP single speed feature pump, Jandy CL580 cartridge filter, Jandy heat pump, Jandy propane heater, spa of unknown size, 3 LEDs in pool, 2 LEDs in surge pond and 1 LED in spa, Eclipse EC-10 Del Ozone oxidizer and 4 Jandy laminars with Jandy CS100 filter built by California Pools in 2015.
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    WardL - In that case I truly only need to dig and install a control valve at one of the deck jets (the one plumbed with the jet that has the least flow). I can then control the flow of that jet to match the lower pressure one. The other two jets are plumbed together and there is a valve that is already installed at the pad that controls those two, so I can essentially bring those down a notch too. Right now I am running the jets at 1950 RPM (Ecostar Pump). If I increase the RPM to 2400, the jet with the least pressure goes up in arch to when I like it. So I am guessing that I the required rpm to make them all the way I want it.
    ****MY WIFE keeps telling me I am nuts and compulsive, that I should leave everything as is. It doesn't seem to bother her that one of the jets has less flow than the rest. Would you guys go through the trouble to fix or just leave as is?
    If it bothers you, by all means fix it. If you had a professional do the install, make them fix it.
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    Jason - I am sure you are aware from all my previous postings that I am a serial DIY'er...so the professional (or lack thereof) was ME <------
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Quote Originally Posted by ssml11 View Post
    LOL!! I'm right there with you! Sometimes we do enough research and get it right the first time and sometimes we learn the hard way! But, either way we keep getting better at it.
    Nov 2011
    Moberly,MO
    1,010
    From the picture it looks to me that the farthest jet is also lower flow. We plumb a continuous loop for our deck jets and get even flow that way. Every thing has to be exactly the same unless you run a valve to each jet and plumb them individually
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Jul 2014
    Raleigh, NC
    59
    It looks to me that you need to increase the pump pressure. If that does not solve the problem then I would throttle back on the valves and that should fix the problem. You do not have enough back pressure to force the water all the way to the last nozzle. Installing a valve for each nozzle would also fix the problem. I am like you, it would drive me crazy if they were not all the same.
    32,000 gallon inground plaster pool/spa combo spillover. Aqua Rite Pro with Sense and Dispense. Jandy iAquaLink Control. Polaris 280 vac. Sheer Descent, Fiber optic deck jet water feature. Vanishing wall. Whisperflo pumps, Pentair clean and clear cartridge filters.
    Apr 2015
    Camarillo, CA
    38
    Hope I'm not too late, but you need to put valves on the jets that have the highest water flow. By trimming back the flow with the valve to the higher flow jet, you force more water to the jet with the lower water flow. This allows you to balance the water until they are all equal.
