Results 1 to 12 of 12
Thread: Time for a through-the-wall skimmer
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Any recommendations for which Hayward skimmer will work? Or does it matter?
    My pool is the 16x48 Intex Ultraframe.
    Hayward only seems to have 1 skimmer on their site, there seems to be more floating about on the internet.
    Hayward's site:
    http://www.hayward-pool.com/shop/en/...-abg/dyna-skim
    16x48 Intex Ultraframe vinyl AGP, 2150 gph sand filter/pump (Intex SF70110), Hayward Skimmer, TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: Time for a through-the-wall skimmer
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Thanks for the link! Ordered and will be here Friday!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,526
    This thread contains some pictures of my Hayward Dyna-skim installation. I have the same pool as you do.
    http://www.troublefreepool.com/showthread.php?t=73741
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Apr 2014
    FOUR cORNERS
    111
    you won't regret it
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    Jun 2012
    MA
    347
    Does a skimmer work with a solar cover on the pool? I am thinking that it doesn't. I always have the cover on unless we are swimming. I have been thinking about adding a skimmer but not sure if it is worth the trouble.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,526
    It will still draw water and particles suspended in it, but won't pull in much floating debris from the surface, since most of the surface is covered. My solar cover has about a 1" gap from the edge, so it does still pick up some stuff floating right near the sides of the pool.
    Pentair IC40 SWG
    Jun 2012
    MA
    347
    Quote Originally Posted by jeffchap View Post
    So the only time a skimmer will work is when there is no solar cover on the pool. I like the idea of a skimmer but it doesn't make sense if you use a solar cover. I can walk around with the hand skimmer and get what is in the pool when we are swimming. I like having the pool covered as I think it makes the pool less inviting to the derelicts in my neighborhood.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,526
    Quote Originally Posted by 1380ken View Post
    It will still work as well as the standard submerged intake on one of these pools, but it loses much of it's effectiveness to skim debris floating on top of the water when a solar cover is in place. There's really no drawback to installing one, unless you just enjoy skimming by hand.
    Pentair IC40 SWG
    Jun 2012
    MA
    347
    Of coarse it will still intake water. It seems to me that it will lose 99.9% of its effectiveness to skim debris floating on top of the water when the solar cover is in place. The draw back would be time and money on the installation for no gain. When I take the solar cover off to go swimming, I will have to skim by hand anyway. Unless I wait a couple of hours for the skimmer to do its thing.
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Thanks! I bookmarked some already, and I'm adding yours to them.
    May 2014
    LA, USA
    16
    I second what POPPA S said in that you won't regret installing the skimmer. I have had several AG pools and this is my first with the skimmer installed which does a great job at clearing debris. I also use a solar cover frequently and the skimming is reduced but once the cover is rolled up the skimmer quickly clears the pool.
    http://www.troublefreepool.com/threa...491#post666491
    AG-Intex Ultra Frame 32 ft x 16 ft x 52 in, Water Capacity (90%): 14,364 Gal, Hayward SP1091WM Dyna-Skim Above Ground Pool Skimmer Kit
    Intex 2650 GPH Sand Filter Pump & Salt Water System CS20110
    3/4" Extruded Polystyrene Foam Board Insulation, Gorilla Floor Padding
    Borated sparkle added
