Thread: Intex Sand Filter vs. Intex Cartridge Filter (with Unicel filter) for 18x48 AG pool?
    Apr 2015
    Western, WA
    37
    Hello,
    Starting ground prep for a new 18'x48" Intex Ultra frame. I was planning on getting the 2800 GPH Intex sand fileter/pump combo for $136 delivered from Amazon. However, the 'school' portion of this site says that cartridge filters can be better. In know the Intex cartridges have a bad reputation, but I understand that the Unicel brand are great. My question is, the 2800 GPH sand filter or an 2500 GHP Intex cartridge filter with Unicel filters--which would serve me better? The pricing is close enough, that cost isn't a factor for me. I just want to get what is best both in filtering ability and longevity.
    2800 GPH Intex Sand Filter, $136 + sand: http://www.amazon.com/dp/B00GSPHS1U/...N2EPXKIY&psc=1
    2500 GPH Intex cartridge filter, $95 + filters: http://www.amazon.com/Intex-Krystal-...rds=intex+pump
    The pool will come with a 1,500 GPH cartridge filter, but I'm planning on not even using it.
    I'm leaning toward getting the sand filter.
    Thanks for any thoughts that I should consider.
    Jason
    AG Intex Ultra Frame 18x48 - new for '15. TF100 test kit. Intex 3,000 gph sand filter/pump, Solar Cover, Intex magnetic pool light, Hayward Skimmer, Laars 250kBtu/hr NG heater. Intex SWG.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Intex Sand Filter vs. Intex Cartridge Filter (with Unicel filter) for 18x48 AG po
    From what I have read here the Intex sand filter is quite a bit better than the Intex cartridge filter. But, I have no first hand knowledge.
    Congrats on the new pool!
    Get the sand filter, won't be disappointed
    Intex Ultra Frame 18' x 52"
    Intex 3000 gph Sand Filter Pump, Intex Salt Water System SWG
    Hayward Thru Wall Skimmer and stock return line
    Two Hayward I lets
    Florida/Alabama
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Sand filter.
    The 2500 carts don't allow enough flow rate as it comes from the factory. With the cart filter, you'll need to have extra carts on hand soaking in cleaning solution for a quick change out when dirty.
    You will lose less pool water with the carts, but that is offset by the greater use of water for rinsing the carts.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    I've used both - sand filter all the way. Less hassle and does a better job in my opinion.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
