Results 1 to 8 of 8
Thread: did I almost kill myself?
    MugZona's Avatar
    Jun 2014
    60
    Cleaned the cartridge filter today, and inexplicably, I forgot to open the air release valve before taking off the belt and trying to take the top of the filter off. (Of course I didn't forget to turn off electricity to the system.) Finding it difficult to take off the too, I suddenly realized what I did, and I opened the valve. Cleaning went as planned.
    Just how bad WAS that, and how lucky am I to be typing this? How big a catastrophe did I avoid?
    13,000 Gallon IG Double Roman End with Steps PebbleTec Seafoam Green Pentair Clean & Clear Plus Cartridge Filter 320 1 HP Sta-rite pump (MPR6E-147L) TF-100 test kit Kreepy Krauly Cacuum
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Re: did I almost kill myself?
    Nothing catastrophic with that. All you were doing was trying to open a sealed chamber. Pulling off the top makes the chamber larger, so in essence making the chamber larger, which creates negative pressure. Without releasing the pressure you would have needed superman strength to pop off the lid.
    Getting the lid back on square and lining up the V band when your done is the bigger challenge
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    If you have compressed air in the filter, the top can come off quite violently. It could potentially cause serious harm.
    Support the site
    38,274
    But the pressure is relieved the instant the pump is turned off ... Right? As long as the pump is off there should be no danger.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Pump off/no pressure/no danger.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    If the pump was off, you were just pulling it against a vacuum. When I turn my pump off my pressure gauge goes negative because of the water trying to return to the pool.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    In most cases, with the pump off, the pressure goes to zero to slightly negative. So no real risk. I have seen people try to remove the top with pressure, which can be dangerous.
    Support the site
    MugZona's Avatar
    Jun 2014
    60
    Thanks everyone!
