Results 1 to 9 of 9
Thread: nature 2
    Apr 2015
    cinci/ohio
    3
    nature 2
    Do you guys have an opinion on the nature 2 sticks...they are really expensive and I haven't seen any evidence they really do anything useful. Love to hear your opinion.
    Thanks Papa
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: nature 2
    Welcome to TFP!
    For pools, they aren't helpful since the copper and zinc can stain plaster surfaces and algae can be prevented with chlorine alone (at the appropriate level -- see the Pool School). For spas, they work in conjunction with non-chlorine shock (MPS) if you want to use a mostly non-chlorine, non-bromine method for disinfection. You still need to use chlorine on occasion since MPS doesn't keep the water as clear as chlorine.
    Apr 2015
    cinci/ohio
    3
    Re: nature 2
    I use chlorine, If I read your post correctly they are of no value to me...correct?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: nature 2
    Quote Originally Posted by 392papa View Post
    Yep. Plain old bleach keeps algae at bay AND kills germs and bacteria that Nature2 doesn't. If you want an eyeful, use the search box for Nature2. There are some horror stories about the mineral packs breaking and filling the pool with metal pellets, and lots and lots of threads about metal stains and green hair.
    Have you checked out Pool School yet? ABCs, How to Chlorinate, and Recommended Chemicals will show you how simple it can be.
    Apr 2015
    cinci/ohio
    3
    Re: nature 2
    Thanks for you help.. I have a 400 gal hot tub not a pool just checking to make sure I wasn't missing anything
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: nature 2
    You'll want to read Using Chlorine in a Spa since I presume you may be using Dichlor-only and that will build up Cyanuric Acid (CYA) over time making the chlorine less effective. If you want the water to last at least twice as long between water changes and stay in good shape, then you'll want to start out using Dichlor until the CYA gets to 30 ppm or so and then switch to using bleach. However, after switching to using bleach you'll need the TA to be lower and should use 50 ppm Borates. This will help keep the pH more stable. About once a month you'd use Dichlor for a day to make up for some CYA that is lost. Read the article as it should give you the details.
    Apr 2015
    SF Bay
    10
    Re: nature 2
    Can nature2 be used without MPS as a backup to chlorine-after-soak? I think chem geek said somewhere that the silver ions alone should prevent bacteria from multiplying, but can't handle bather waste. Main reason I'm wondering is for when I'm out of town and not using the spa but can't add chlorine.
    Aquaterra Verona Costo Especiale
    290 gal (nominal, haven't measured a fill yet), Ozonator, only 110v so the pump runs often
    PH 7.2, TA 90, CH 130, CYA 30, Borate 50
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: nature 2
    It's a weak backup, but sure if you want to use it that way you can. The best is to maintain an FC level at all times, but it's true that if it drops too low or to zero that if there's silver ions in the spa then that should inhibit bacterial growth. Of course, you could just see about using MPS instead since it won't deplete as quickly as chlorine and that would provide greater disinfection capability so be less risky of things going south. It's easy to switch back and forth between using MPS vs. chlorine or even having some of both at the same time. It's just that MPS will measure as chlorine in the tests, but with Nature2 it doesn't really matter since both act as a disinfectant (at least at hot spa temperatures, for MPS; chlorine does well even in colder temperatures).
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: nature 2
    Welcome to the forum 392papa
    Please add you pool and or spa and equipment into to your signature as outlined here - - > http://www.troublefreepool.com/conte...etting-started
    Solar Blanket, Well Water, Borax Added. 76
