Thread: Another Raypack 2100 thread
    Aug 2014
    Spring, TX
    7
    Guys,
    I've been out of town a few weeks, and we've gotten quiet a bit of rain down here in Houston, and when i came home I was unable to get my Raypack 2100 to light.
    At first, it would go to SPK however it would not spark at the pilot. After a battle, i have destroyed a massive wasps nest which was inside the front control panel of the heater. However, now that the pilot is getting lit, the main burner i don't think is opening to light. The pilot will light (i've verified this by removing the front panel. The flame initially is very blue, but after about 15 or so seconds it changes to yellow. The gas valve is open all the way, and I do not believe it is a lack of gas problem), however, the heater continues to SPK no main burner light. I can smell gas after the pilot gets lit, however, I don't believe the heater is acknowledging the pilot is light.
    I've checked all the wire connections, everything looks good. Cleaned the pilot. I've tried power cycling in case it was the ignition lockout. I've done some reading on a "ground" at the pilot, however, for the life of me I can't find a wire other than the 24v spark that goes to the pilot assembly...
    Any other ideas?
    Thanks!
    Spring TX, 20,000 gallon in ground plaster pool, about 30 years old, attached spa, Raypak RP2100 heater, Whisperflo WF-26 Pump, Hayward Pro Grid DE Filter, Circupool SI-45 SWG
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Another Raypack 2100 thread
    From my experience, if the unit continues to spark, SPK, you need a new pc board controller. There is no other wire going to the pilot assembly. What is happening is that the system is not recognizing that the pilot lit.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
