Results 1 to 15 of 15
Thread: My pool looks like a swamp!
    Jun 2012
    Spring, TX
    7
    I haven't been on here in a while... and am in need of some good advice. I did a really stupid thing and didn't bother covering my pool last winter, and shut the pump off because the inside basket broke. I could just kick myself and I have no idea what I was thinking...so anyway. Now it's Spring and I have to clean this mess up. I am in the process of draining it right now...with a water hose! I suppose it will take a couple of days this way, but I don't have an electric pump and didn't want to go out and spend the money right now. The thing I need to know is after I get it drained and get all the gunk out, how do I go about cleaning the walls before I refill it.
    10,400 gal. round AG. 1.5 hp Sand filter. Aquacritter Robotic cleaner.
    Casey's Avatar
    SW PA
    10,452
    Re: My pool looks like a swamp!
    Hi Shirleye. You should not drain your pool. You will run the rist of unseating the liner and could possibly tear it. Stop draining the pool now. Get a leaf rake and attach it to your pole and start scooping out all the winter debris. Fill the pool, start the pump n filter as directed and start SLAM'ing your pool as outlined here:
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    SLAMing Your Pool
    Do you have a TF100 of K2006 test kit?
    Jun 2012
    Spring, TX
    7
    Thank you Casey. My plan was just to drain it down to about 2 ft. just to make it easier to get the debris out of the bottom. I thought as long as you didn't drain it completely, it was okay to drain it some. I know the liner could shrink if it's completely emptied, and especially if it's really hot and sitting for a few days. Once I remove all the debris that I could get out, I was going to refill it and start the "slamming" process. Is this a bad idea? I do have a TF100 test kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,043
    You have the right idea.
    If you have a pool vacuum, the hose for that would siphon the water out a lot faster.
    PS
    Jun 2012
    Spring, TX
    7
    Thank you Richard320. That's a great idea...wish I had thought of it. I know pics are great, but I am just so embarrassed at how bad my pool looks, I didn't really want to share that!
    Casey's Avatar
    SW PA
    10,452
    Get all that garbage out n refill it. You should be fine with leaving a couple feet of water in the pool. Glad to hear you have the TF100. You're on the right track! If you have any questions, just ask!
    Jun 2012
    Spring, TX
    7
    Thank you Casey!
    Casey's Avatar
    SW PA
    10,452
    How are you coming along? Arms tired yet?
    Oct 2007
    Asheville, NC
    43
    Don't feel bad, I had a similar situation last year. I had a slow leak in the fall and was letting it go so I could get an idea of where the leak was. It stopped draining about one foot down, but between this and that I didn't take care of it and left the cover off all winter. In the spring I found the leak and patched it up, but not before some frogs found the pool. And had babies. Hundreds of tadpoles.
    Johanna, mass murderer of tadpoles.
    1984 vintage 16x32 Doughboy vinyl AG w/deep end, Sand Filter
    Jul 2012
    Seymour, In
    49
    Pictures would be great so you can show off the progress you make going from the swamp to the crystal clean pool.
    24x54 ABG 15,200 gal, 22in Ecco Sand Filter, 1.5HP Ecco pump
    Jun 2012
    Spring, TX
    7
    I took the cowards way out and hired someone to clean it out! lol! It was worth every penny too! Now I have it refilled and am ready to start all over. I was searching on here for pool "start up" because it's been a long time since I had to start from scratch.
    Jun 2012
    Spring, TX
    7
    Quote Originally Posted by Casey View Post
    Well...I am a big wimp! I took the cowards way out and hired someone to clean it out! They finally came out yesterday and I now have it refilled and ready to start all over. It's been a while since I started my pool up, so I am searching how to start from scratch. I think I need to run the pump for a few hours and then test it to see what it needs. Is that right? The filter/basket is really dirty and has lots of leaves and debris in it. I can't get it opened, so now I am waiting for my neighbors son to come and help me get it opened.
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    For the amount of time it would of taken you to clear it yourself, I'm sure you made a good choose
    Intex ultra frame 26'x52" above ground pool
    Intex ultra 18'x46" above ground pool retired
    Jun 2012
    Spring, TX
    7
    Thanks Piper Mike. I'm pleased with how it came out!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Rubber mallet to tap the ears on the skimmer cap.
    Here is an intro to TFPC, TFPC for Beginners and ABC's of Pool Water Chemistry and Recommended Levels
    The #1 thing to do is keep your chlorine level above the min level for your CYA level. If you do this algae will not grow. Chlorine CYA Chart
    All the rest of.the levels can be adjusted easily enough.
