Results 1 to 7 of 7
Thread: Chlorine may be hard on bathing suits
    Saturn94's Avatar
    Mar 2015
    Virginia
    499
    This off topic side conversation has been split off of this topic. JasonLion
    Just keep in mind that what's safe for you may be hard on bathing suits depending on the material they're made of. In other words, if your going to swim at close to SLAM levels, wear an old suit. (or no suit )
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    30,416
    Re: Safe to swim FC chart?
    Actually, it may be about time to put that (old suit) idea to rest. Over the years, I doubt we have seen but maybe one or two reports of swimsuit fade.
    Now, if there is no CYA in your pool, the FC is quite a bit more aggressive so pay attention to the chart but if you are in the safe range, it truly is safe.
    Saturn94's Avatar
    Mar 2015
    Virginia
    499
    Interesting. It was my understanding that the issue had to do with CL attacking the stretchy (spandex?) material used in many bathing suits.
    Re: Chlorine may be hard on bathing suits
    That is correct as far as it goes. The thing is it very much depends on the active chlorine level, which depends on both the FC and CYA levels. Because of the way CYA works, with CYA above zero it is nearly impossible to get FC high enough to be a problem for swim suits. While if CYA is zero then it is quite easy to get FC high enough to be a problem.
    Saturn94's Avatar
    Mar 2015
    Virginia
    499
    Quote Originally Posted by JasonLion View Post
    That is correct as far as it goes. The thing is it very much depends on the active chlorine level, which depends on both the FC and CYA levels. Because of the way CYA works, it is nearly impossible to get FC high enough to be a problem for swim suits. While if CYA is zero then it is quite easy to get FC high enough to be a problem.
    Thanks for the clarification.
    Orlando, FL
    690
    Suits have never faded in my home pool. My suits faded all the time when I swam at the gym. They would fade within two weeks.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    30,416
    Probably a good example of no CYA in the water and one of the reasons we suggest it (minimally) for indoor pools as well
