Thread: Is low TA okay is CSI is inline?
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Just tested the pool...TA has gone down, but CSI is inline. Should I raise TA or leave it there?
    pH: 7.8 (added 4oz of HCL after test)
    FC: 4 (Added 1 qt of bleach to bring up to the target of 5)
    CC: 0
    TA: 55 (5 drops turned it red...6 drops turned it bright pink)
    CH: 375
    CYA: 30
    Temp: 81
    CSI: 0.07
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    Re: Is low TA okay is CSI is inline?
    You don't really want TA below 60 unless you are using borates. However, 55 is very close to 60, so you don't need to rush to raise it right this instant or anything.
    In addition to affecting CSI, TA affects how chemical additions change the PH. When TA gets (way) too low the PH can swing around wildly when chemicals are added. We want the PH to be fairly stable, so don't want TA getting too low.
    30,402
    Color change tests are not completed until the last drop makes NO color change whatsoever. If 6 drops changed the color, you need to add more until the color doesn't change at all.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Thanks, Jason. pH has been stabilizing a bit. It's nice to not have to use two or three gallons of HCL every week anymore. I will go ahead and toss some baking soda in tomorrow.
