Thread: No power to pump or Polaris
    Unhappy No power to pump or Polaris
    Hi,
    I really need some help. I just had my saltwater pool converted from 110 to 220 and the Polaris line as well. The issue is that now neither the pool pump nor the Polaris will turn on!!! The electrical meter showed the voltage at 220 but I can't get anything to turn on. I am hoping we are just overlooking something simple. ANY constructive advice would be much appreciated.
    Thanks in advance,
    Misty
    mistymathews@bellsouth.net
    No power after conversion to 220
    Hi,
    I just had my pool converted from 110 to 220 and since then my pool pump will not come on. The Polaris line was converted as well. When the meter was hooked up it shows that there us power but it will not turn on...... Nothing! Any help would be appreciated.
    Misty
    Topics merged. Please only ask a question in one place. Thanks JasonLion
    Re: No power to pump or Polaris
    Can you provide more details including pictures? Who did the conversion? What switches do you have? Was the equipment reconfigured for 240?
    Also, please only post once to keep answers in one thread.
    Support the site
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Re: No power after conversion to 220
    Need a little more info. Did it start with a sub panel at the pad or just plugs. Was new wire pulled. It could be a number of things and as simple as the circuit was not turned back on. Who did the work.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Do you feel comfortable using a multi-meter to check power? If so, trace backwards from the pump towards the main electrical panel until you get to somewhere that has power. Whatever is right after that is where the problem is.
