Results 1 to 9 of 9
Thread: Polaris Booster Hums for a second but won't start
    Upon opening our pool last weekend I noticed that our polaris booster pump will hum for a few seconds when I turn it on but won't start. I replaced the capacitor already as it seemed like that was a common thing to break that is relatively easy/cheap to fix. Are there any other easy things to check? I don't want to spend another $30/$60 on troubleshooting components if i'm going to need a new motor in the end anyways.
    The actual model is an A.O. Smith 1081.
    Thanks in advance for any advice...
    -Jason
    Re: Polaris Booster Hums for a second but won't start
    It's probably seized. You can get to the back of the shaft by removing the shaft cover. Then a 1/2" wrench can spin the shaft to break it loose.
    Support the site
    Quote Originally Posted by JamesW View Post
    Thanks for the tip James. I went out and tried that and unfortunately no luck. I was able to spin the shaft...but the motor still just hums then shuts off. Probably burnt out you think?
    I'm not sure if that motor has a start switch. If it does, it migh be corroded or stuck open. How old is the motor? Can you post a picture of the back with the electrical cover off?
    Support the site
    Thanks James. I'm at work now so I can't take the plate off...but here's a pic of the nameplate of the motor. We just bought this house last year and some of the pool documentation is lacking...not exactly sure how old it is. Should I take the cover off when I get home and look for obvious corrosion?
    Attachment 35310
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    There is also a possibility that the capacitor is gone. If there is a safe was to try and help spin it at start up that would tell you if it's the capacitor.
    Solar Blanket, Well Water, Borax Added. 76
    Quote Originally Posted by Kiss4aFrog View Post
    Thanks! I actually replaced the capacitor on top of the pump first. It was only $14 and easy to do...and my initial reading said that was the most common part to break. Unless you're talking about a different capacitor internal to the motor I think I've already changed it...
    The serial number indicates that the motor was manufactured in 2004. Eleven years is a pretty good run. It might be time for a new pump if the voltage is good and you can't find anything obvious.
    Support the site
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Yes you did in that first post and I completely missed it. Nope, that's the one I was thinking of, sorry.
