Thread: Ground Cloths for Concrete
    I have a small Intex Easy Set that I put up seasonally on a concrete patio. The past year, especially, I had a lot of mildew/mold growing on the ground cover under and around the pool. I've always used the Gorilla/Rhino pad type cloths. Is there something that would be better as far as mildew/mold goes? This is on concrete, so I guess I'm not getting the drainage that I would normally get if it were on grass and the cloth tends to stay wet which causes the mildew/mold. Anyone have any experience with this? Thanks!
    15 ft x 42 in Intex Easy Set Pool on a 20 ft x 20 ft Concrete Pad
    Casey's Avatar
    SW PA
    10,438
    Re: Ground Cloths for Concrete
    Where there is water, you'll always have mold n mildew. If I were to take my liner out of my pool, I'd find the same thing on my gorilla pad. I don't think there is going to be an easy solution. If it were my pool, I'd cut the gorilla pad as close to the pool as possible n just deal with it.
    MrsDimples's Avatar
    Jun 2014
    England
    47
    I've had an intex easy set & metal frame pools up, over the last 2 summers on a concrete base. I used EVA camping mats with no bother. Solid ones underneaths & 'holey' ones around the outside.
    Intex 10ft Metal Frame - 1,185 gallons
    Intex 530 gall. per hour Filter Pump (Model No. 58604) - Cartridge
    Chlorine / pH dip sticks
    Intex 3kw Heater
