Results 1 to 7 of 7
Thread: CYA help, please
    tgenre's Avatar
    Apr 2014
    Denham Springs, LA
    22
    Cool CYA help, please
    My pool was just emptied, acid washed and refilled. I can now see my Diamond Brite instead of white "cream"! It looks great. I'm tweaking the chemistry and have been testing/adjusting daily to get to the sweet spot. I'm rather puzzled this morning. Yesterday, my CYA was 30. I put a gallon of liquid conditioner in the pool yesterday afternoon and ran the pump all night. This morning, my CYA is still 30. I know that with solid CYA, it can take a week. I've not experienced this with liquid CYA. Here's my numbers this morning:
    FC: 3
    Ph: 7.8
    TA: 100
    CH: 325
    CYA: 30
    Salt: 3600
    Borates: 0 (haven't added yet)
    CSI: 0.1
    Explanation or advice is appreciated! Of course, my concern is adding more and then discovering I have too much CYA.
    18k Gallon gunite with Diamond Brite Bahama Breeze, Intellichlor IC20 SWG, Intelliflo Variable Speed Pump, Pentair Clean and Clear
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: CYA help, please
    Liquid takes time to show up on testing also. It is one of the reasons we just recomend solid in a sock an the liquid doesn't give a lot of value add for the additional cost.
    Don't add more, it will eventually sho up on testing.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Give the Cya some time, and retest in several day to get a new reading. Just assume what you put in is there and plan your FC for it.
    Watch the pH. At TA 100 and a "new finish" it will want to rise on you, especially with the SWG.
    Borates are totally optional, so don't worry about them right now. Get a feel for managing Cya, pH, FC, and TA for now.
    Essential Links:
    tgenre's Avatar
    Apr 2014
    Denham Springs, LA
    22
    Thank you both. I'm watching the ph daily. My pool is 1.5 years old and I've ALWAYS had to add MA more frequently that I thought I should. I was hoping this season would be better, since the plaster has some age on it now. I guess removing the "cream" makes it like new again? I'm currently dropping the Ph and aerating in hopes of getting that TA down some (this was not an issue before the drain, wash and refill).
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Essentially yes, you've exposed a lot of new surface area. Good job though. It sounds like you have it under control.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Isn't it great when you can test your water, understand what is happening and know what to do make it better?!?!? Very nice!
    tgenre's Avatar
    Apr 2014
    Denham Springs, LA
    22
    Thanks guys!
