Thread: North Eastern Ohio pool opening
    Jul 2014
    Hudson Ohio
    142
    I think I am going to open the pool next weekend. The last time I looked under the cover before the ice set in the water was crystal clear. I probably need to add a thousand gallons to the pool. I had tried one of the skimmer covers so as not to have to drain it down but when ice set in the thing kept leaking so I drained below the skimmer anyways. Oh well I won't try that again.
    Is there anything in particular I should look out for during the opening?
    Should I bother testing the water before I refill it or just do it after?
    I need to replace the eyeball insert for the return totally screwed that up removing it when I closed the pool in the fall. I am also thinking of hard plumbing the lines this season.
    24'x54" AGP 13,500g AquaLeader Sentinelle | Hayward Voyager CC150 sqft cartridge filter | Hayward 2hp 2spd pump | Hayward Aquaray Cleaner
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: North Eastern Ohio pool opening
    If you are chlorinating with pucks then you might want to test your CYA to make sure it isn't too high before filling.
    Jul 2014
    Hudson Ohio
    142
    Quote Originally Posted by pooldv View Post
    thanks pooldv, I do use tablets in an external chlorinator but did monitor CYA regularly last season. I took a hybrid approach using the tablets to maintain and adjusted the chlorine levels with bleach. So far that approach seemed to work pretty well and I only ran the pool 3x per day for 3 hours each cycle.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    You'll need to fill it up to the skimmers to get the pump running and you need the pump to do the SLAM. Add water, test and adjust pH if needed and SLAM.
    Solar Blanket, Well Water, Borax Added. 68
    DFW, TX
    24,502
    Aacckkkk! Somebody spammed your post!
    Sounds like you have everything under control and are ready to go. Send us a pic of your swamp bellyflop.
