Thread: Trouble with heating spa with Master Temp
    Apr 2015
    San Dimas,California
    3
    Unhappy Trouble with heating spa with Master Temp
    When I turn on heater and press heat spa button heater ignites the temp stays at 71 but does not heat spa?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Trouble with heating spa
    We need more information. Like what sort of equipment you have. I just saw our other post where it only says Master Temp as your heater type. Please add the specifics here.
    I am going to delete the other thread as there is nothing in it to go on. Please ask and fill in your equipment details using this thread.
    Essential Links:
    Apr 2015
    3
    Listed more information in my signature.
    In ground pool+ spa(35,000 gallons).Pentair "Clean & Clear cartridge filter system.
    Pentair "easy touch"controllsystem
    Pentair Intelliflo VS-3050 variable speed pump.
    Pentair MasterTemp 400 natural gas heater.
    Re: Trouble with heating spa with Master Temp
    I assume you have set the heater so it's target temperature is higher than 71 degrees?
    Do you have a heater bypass? If there is a bypass and it is currently setup to bypass the heater, that would prevent the heater from working correctly.
    Apr 2015
    3
    What does a heater bypass look like,is it equipment connected to my heater or is it like a computer command I could have accidently initiated from controll panel?
    A heater bypass is plumbing external to the heater which can be set (with a valve) to route water through the heater or past the heater. If you are unsure a photo of the plumbing connected to the heater would make it very clear.
