Results 1 to 8 of 8
Thread: Anyone use Sun Rings?
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Anyone use these to help conserve energy? Thinking about one for spa. Thoughts?
    http://http://www.solarsunrings.com/about.html
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
    38,524
    Re: Anyone use Sun Rings?
    Search the forum for their use in pools, not recommended. But might work in the spa to retain heat.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    There have been quite a few discussions on these. Doesn't seem to get good reviews here.
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Great! Thanks!
    ~Wendy
    Donldson's Avatar
    NW Ohio
    2,917
    I used them for a couple seasons in my pool. More a hastle than they were worth IMO. A single one on a spa might be a much better situation however. It wasn't that they didn't work, it was that putting a dozen of them in the pool was a pain and then wind would bunch them up, gunk grew in water on top of them, and other minor issues like that.
    If I had a spa I would probably use one in it, since I already have them.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    I don't think I would want to deal with a bunch of them on a pool for sure. Here in TX the pool will be hot for a large portion of the year - but I will be heating my spa with propane - which can be pricey - so I was thinking of ways to help conserve a little energy. It will be a 7' round spa - so I would think that one 5' spa ring would help a little - and it shouldn't be too much of a problem to move it out of the way. But I can TOTALLY understand the struggle of having tons of them - I can't even imagine how you would deal with a bunch on the pool every day! But the idea that they feel dirty after you use them for a while - not sure I can deal with that.
    Anyone have a specific brand that is better than another? Since I am only having to buy one, price difference probably wouldn't be a big deal.
    ~Wendy
    38,524
    You want the biggest you can fit. I would even suggest buying a piece of solar cover and cutting it to shape.
    Apr 2015
    SF Bay
    10
    Quote Originally Posted by Sunbaby View Post
    There are also a lot of closed foam floating insulation blankets for sale online. I got one from rhtubs and will let you know if it reduces my energy consumption at all.
    Aquaterra Verona Costo Especiale
    290 gal (nominal, haven't measured a fill yet), Ozonator, only 110v so the pump runs often
    PH 7.2, TA 90, CH 130, CYA 30, Borate 50
