Results 1 to 17 of 17
Thread: Hayward sand filter leaking
    Apr 2015
    canton michigan
    14
    Hi Everyone, I have a 10 year old Hayward fiberglass sand filter.It started leaking underneath, My pool guy came out he and i undid all the fittings
    tilted it and really could not see any cracks underneath. He thought it could be leaking from a small seam on the bottom & said because of all the
    pressure on the sand filter, Any kind of patch that i do would not hold.Bottom line he say's, I need a new sand filter cost would be $854.00.
    Please give me any suggestions, Like most money is tight. Thank's for your help!
    Inground fiberglass pool 6000 gallons
    Re: Hayward sand filter leaking
    Welcome to TFP!
    If the filter is indeed cracked, you will need to replace it. There is some chance the water is coming from somewhere else, though that isn't all that likely. Check to see if there could be a pin hole leak spraying water onto the filter from somewhere else.
    Apr 2015
    canton michigan
    14
    It is definitely coming from bottom of filter but i can't see any cracks.Is there any chance a fiberglass repair kit or paste will at least slow it down or is that a waste of time.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Horse
    I've never repaired one but for the cost of a kit vs a new filter it would seem to be worth the try. It makes sense a patch should hold if you clean and prepare the surface properly.
    Does it only leak when running ??
    Have you thought about adding a dye inside the filter, putting the multiport to waste and plugging the waste output and momentarily turning on the pump to get some pressure ??
    Solar Blanket, Well Water, Borax Added. 68
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That honestly sounds a little high for no bigger filter than you need.
    As for repair, it couldn't hurt to try, but you'll need to find out exactly where to make it.
    Essential Links:
    Apr 2015
    canton michigan
    14
    Thank's, for the welcome frog & patrick. Yes filter only leak's when running, What kind of Dye frog & does that have a chance to seal leak?
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    I think red, blue, or green liquid food coloring would work. Yellow would not be dark enough. You can get a 1 or 2 oz bottle at your local food market. The bad thing is that it will get in your pool. You could open the top of your filter and dump it and mix it in with a paint stir stick or some such thing. Run the pump long enough to see it leak then back flush the heck out of it.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Smykowski's Avatar
    Sep 2011
    3,065
    Where is the drain hole on that thing? Directly on the bottom, or more near the side?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I was thinking blue food coloring like Steve said above.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Not sure of exact model of filter. Most likely one of the poly pro models that do not patch well. Better to buy a new filter. Going back only 10 years it must be one of those. If you have the model number that would help.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Apr 2015
    canton michigan
    14
    Sand filter on Recirculate
    My Hayward sand filter is crack, and leaking water. I have someone coming out next week to replace it.
    My pool guy said i could put sand filter on Recirculate, so i don't lose so much water, will chlorine from feeder still
    get into pool on Recirculate? Right now I only run sand filter for about 4 hour's a day.
    Thank's
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Sand filter on Recirculate
    It depends on where the feeder is in the plumbing. Do you have a photo we can look at?
    MY gut feeling is yes, but I'd like to see how the pipes run.
    Support the site
    Apr 2015
    canton michigan
    14
    I will have my son send pic tomorrow, I'm not good at technology.
    Thank's Tim!
    May 2013
    Long Island NY
    419
    I have a Hayward s200 sand filter. I just checked and there about $475 shipped. Over 800 must be for them to order and install. Ouch!
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Apr 2015
    canton michigan
    14
    Here's a picture of my piping. I want to know if the chlorine gets into the pool when the filter is on recirculate. Thank you.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Yes the flow is still going to the multiport, past the filter, through the heater and then through the chlorinator and to the pool.
    Apr 2015
    canton michigan
    14
    Quote Originally Posted by Kiss4aFrog View Post
    Thank's Frog, I guess I'll just keep filter on recirculate & test water every couple day's.
    Hurt's to spend 500 dollar's, but did have sand filter for 10 year's.
