Results 1 to 7 of 7
Thread: How to get leaves etc off of my new solar cover
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Looking for tips on how to get leaves etc off of my new solar cover. My pool is surrounded by oaks and pines on city property next to our property as well as a neighbors ginormous pine west of my pool (which also shades my pool starting at 2:30pm...:sigh: you would think living in the south I'd have a warm pool but due to neighbors shade early in the day it's a struggle. Put on a new 12 mil blue 2 days ago. I normally lose 2-3ppms of chlorine per day and have to add 1 gal bleach per day but I'm happy to report since adding the cover I have only lost 2 Ppms in 2 days which is fantastic........however, after only 2 days we had a bad storm last night and now the solar cover in covered with rain water, leaves and pine needles with some escaping into the pool. I feel like I'm back in the dead of winter faced with cleaning the top and pumping water off the winter cover. Now I'm questioning my purchase. Any suggestions?
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Orlando, FL
    690
    Re: How to get leaves etc off of my new solar cover
    I cut my cover into manageable strips and I use a leaf rake or net to "rake" the leaves into a pile and then I toss them. During the fall and winter, there are a lot and it gets messy. I am never able to get it all off. When it's really bad, I hang the cover on the fence and rinse it before I put it back on. Some people take the cover off in a way that allows most of what is on top to go directly into the skimmer. I have tried this method but I found it to be not much better than just taking them into a pile.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Use a water hose to sweep the debris into the skimmer.
    San Juan Cosala, Jalisco
    53
    As I'm taking my cover off I have a hose handy and I hose off sections about 1 meter wide as they come out of the pool. Of course I'm careful to make sure none of the water from the hose goes into the pool.
    JodieM's Avatar
    Jul 2013
    Brownsburg, IN
    96
    I wait a few days till the water evaps off the top of the cover then do the following...
    Fold both short ends towards center about 3 feet. Fold both long ends towards center about 3 feet. Pull cover off the pool surface straight onto the yard. The fold should hold in any loose leaves and pollen. Then I skim surface with net to get any surface debris and take the cover to the driveway, broom it off, spray it down and leave it in the sun to dry.
    Pool Build Underway! see Building-in-June-Brownsburg-IN
    16x32 Premium Steel Wall rectangle with liner.
    JANDY Pro Series PlusHP High Head Pump, 230/115 VAC, .Full-Rated 1.0HP
    JANDY JS SERIES SIDE MOUNT SAND FILTER JS60-SM with Multi-Port Valve.
    JANDY JXI POOL HEATER - 260K BTU - NG - and an Jandy Tru-Clear Salt Chlorinatior
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Welcome to the forum JodieM
    Plaese add your pool and equipment to your signature as outlined here - > http://www.troublefreepool.com/conte...etting-started
    I guess it depends on how nasty the stuff on top of your cover is. I use a hose screwed into my return and wet mine and try to scoop up all the leaves and needles I can. Previous owner planted pines just on the other side of the apron around the pool so I have two that have branches almost overhanging the water !! Don't get me started on needles !
    Once I've scooped up all I can the rest goes into the pool as I roll up the cover on a reel. I also use that hose and the pool brush to occasionally wash down the top of the cover to keep it clean. If I need to add water then I'll use the garden hose.
    Solar Blanket, Well Water, Borax Added. 76
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Thanks all. I'm certainly gonna try the hose method. It's suppose to rain for the next week so a see a big mess a comin!
    Montgomery, AL
