Thread: Keepy Krauly Shot after 2 seasons
    May 2013
    Dallas area
    85
    Hello I have Kreapy Krauly Legend pressure side pull cleaner and it appears to be shot. Wheels slip on gears, get stuck in corners, rear hose knobs worn and even the hose a litte, bag shot.
    This surprises me. Shoudl I be surprised? It seems a rebuild is quite a bit of money. A new one is about $400. So question is is two year resonable for a rebuild? If it is would I be netter off with a robot? I have seen some for about $600
    Thank you,
    Anthony
    Dallas area, free form, quartz finish, flagstone, pentair cartridge, vs pump, swg
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Keepy Krauly Shot after 2 seasons
    I'm very biased toward Robots. My advice to almost anyone on a cleaner, is buy the very best Robot you can possibly afford.
    Essential Links:
    30,403
    You don't give your pool size but, unless you have a small pool, a good robot is the best choice.
    Orlando, FL
    690
    I have a small pool and I wish that I had gotten a robot from day one. Not having to connect it to anything but a power supply and it just works. Even if it breaks after a year, I would be happy. I am amazed at the amount of sand that it collects and it does a great job filtering the water. Much better than my Kreepy KrAuly Lil Shark.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    May 2013
    Dallas area
    85
    Thank you for the replies. The pool is about 36 by 18. perimeter is 100 ft or so. I plan on starting to research robots.
    Thanks again,
    Anthony
