Thread: Question about Heaters and Alkalinity
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    getting a new raypak heater monday and have a question.
    My old rakpak just died after 19 Years of service !!!!
    I use TFP Recomendel levals for a SWG/ Fiberglass
    ( my pool is really gunite with fibertech surface )
    I keep the Alkalinity between 60-80
    My Raypak heater manual says Alkalninty should be 100-120
    Is this going to be a issue ???
    Will lower Alkalinity damage the tubes in the heater ?
    thanks for any advice ...
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Re: Question about Heaters and Alkalinity
    No, lower TA will not damage the heater. There is some chance that they could use it to deny warranty coverage, but not because it has any actual effect on the heater.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Ok, thanks I won't worry about it ..
    Sean Hannon
    Mar 2011
    441
    Quote Originally Posted by JasonLion View Post
    When referring to Raypak, they will try to do everything they can. "Sorry we can warranty this since we can't determine that the truck delivering it had the proper PSI of air in it's tires".
    20X40 30,000 gallon gunite pool
