Results 1 to 8 of 8
Thread: Considering buying a Intex sand filter pump
    May 2013
    Tucson, Arizona.
    7
    I have an above ground pool 15x42 made by Swim N Play. I adapted a small intex pump, it does work OK. But it is now starting to shutdown after 15 minutes or so of running time. So I am thinking of upgrading to a an Intex Krystal clear sand pump. The one I am looking at has flow rate of 2,150 gallons per hour.
    Looking for tips on similar set ups, if the small pump worked well, this should definitely be worth a shot. I have no experience with sand filter pumps.
    Any tips or suggestion are welcome.
    Re: Considering buying a Intex sand filter pump
    The Intex sand filter and pump systems are excellent for the price, far better than the Intex cartridge filters.
    May 2013
    Tucson, Arizona.
    7
    Well, I went ahead and bought the sand filter pump. $135 was a more than reasonable price, considering to replace the same I have is around $47 dls. plus cartridges. Can't wait to hook it up tomorrow. Thanks for the input Jason.
    http://www.walmart.com/ip/Intex-Krys...-Pump/33153775
    4/17/2015
    What a difference this pump makes. I am super pleased with the purchase. I also bought a Taylor K-2005 kit. I didn't realize that it was the K-2006 that I needed since I want to have the right tools when shocking. So I'll invest in that separate kit as well. I also need a reliable salt testing kit. Will do some research and purchase from products recommend by this group. The more I search for info in this forum, the more I realize how little I knew about pool maintenance. The amount of knowledge here is amazing, for DIY people you guys are life savers.
    Above Ground Heritage Swim n' Play 15X42. Metal Frame. Intex CS8110 Krystal clear salt water system. Intex Sand pump Model SF70110 2600 gph.
    May 2013
    Tucson, Arizona.
    7
    Well, my CS7110 swg died. Kept indicating code 91, I ended up adding too much salt since that error never went away. Out of warranty. Lasted 2 summers. I bought a new CS8110, I am draining about 40% of the water in the pool using pool math. I was in the middle of slamming the pool.
    One question I have, Intex recommends a CYA 20-40 max 50 ppm. Would it be wise to increase it to 80 if everything else checks ok? ( FC,TC, CC, TZ, CH )
    May 2013
    Tucson, Arizona.
    7
    OK, pool is filled up and pump has been running for a couple of hours is are my test results
    Salt 3690 ppm
    FC 4.5
    TC 4.5
    CC 0
    PH 7.4
    TA 175
    CH 300
    CYA 30
    A work in progress.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Congrats in the new equipment and welcome to TFP! Yes, you should increase your cya to 70.
    Read this TFPC for Beginners
    And this, ABC's of Pool Water Chemistry
    And this, Water Balance for SWCGs
    May 2013
    Tucson, Arizona.
    7
    So far so good on my new additions. I like the SWG and the sand pump running on a timer. Keeps a solid 4.5 FC and 0 CC for the past 3 weeks. Now if you are buying an Intex SWG, I suggest to buy the one that produces 12g per hour, as opposed to 5 grams per hour. I have been running 4 hours a day with no problems.
    By the way, Pool Math is extremely accurate.
    Thanks again for your tips and help.
    DFW, TX
    24,502
    Good news! We like the success stories.
