Thread: Suntouch Control Panel has no power
    May 2014
    Victorville, CA
    3
    I cleaned my swg and upon reconnecting noticed I had no power to my Suntouch panel. I did not do anything but disconnect the swg and as far as I can tell all the wireing is properly connected. I have power to the swg, everything was working last night when it turned at at the set time.
    Thoughts?
    Re: Suntouch Control Panel has no power
    Welcome to TFP!
    Check your circuit breakers, one of them may have tripped.
    May 2014
    Victorville, CA
    3
    Reset all circuit breakers all the way back to the main box, tried the 2 breakers on the control panel itself and still no power to the control panel. Relooked that all the wiring is connected although all I did was disconnect the swg.
    The next step is to get a multi-meter and work backwards from the SunTouch until you get to somewhere that actually has power.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Is there a fuse in the Suntouch? Can't remember for sure, but it seems like there is a glass fuse in my Solartouch.
    May 2014
    Victorville, CA
    3
    Has 2 push button type breakers on the front panel.
