Thread: First time testing with Tf100 kit
    Oct 2013
    Los Angeles, CA
    87
    I tested my pool with the tf100 for the first time today and i was confused with the cya test. We need to have our back to the sun right? When i did this there was my shadow over the test tube which give me a higher cya readinh of 70. But when moved and let the sunlight hit the testtube the cya went down to 40 before i could no longer see the dot. Which method is right for testing cya ? Thank you for the replys =]
    Intex 12 by 24, Intex 2600 sand filter (soon to upgrade), deck under construction
    Re: First time testing with Tf100 kit
    The test is calibrated for full sunlight with the view tube in the shadow of your body (sun to your back).
    Oct 2013
    Los Angeles, CA
    87
    So then my cya should be 70 right ?
    Yes, based on your description, your CYA is 70.
    Oct 2013
    Los Angeles, CA
    87
    Thank you for the clarification
