Thread: Negative CSI
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Negative CSI
    Pool Math says this about CSI, "Less than -0.6 is suggestive of problems for plaster, tile, stone, and pebble pools.
    Greater than 0.6 is suggestive of problems for all pools." Yet the target when importing TFP settings is -0.19 which is less than -0.6. Is there a typo here?
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Re: CSI
    -0.6 is smaller than -0.19, they are both negative and -0.6 is further from zero.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: Negative CSI
    You want to be as close to zero as possible. With zero being the goal -0.19 is much closer.
    chiefwej
