Thread: Easy Touch Temperature Fluctuations
    Apr 2015
    Upper Saddle River
    1
    I have a Pentair Easy touch 8 which if set for 80 degrees will trigger the heater, heater runs gets water to 80 and then reading on panel will bounce to 79 and back to 80 very quickly. Recently I had SPA temp set for 100, I watched the temp get to 100, it stayed on 100 for about 10 seconds and then went back to 99 then 2 min later temp bounced to 101. I have changed the temp sensor but same issue is occurring. Anyone have ideas what's going on here? Do I have a bad sensor or maybe motherboard?
    Scott
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Easy Touch Temperature Fluctuations
    Have you tried calibrating your panel to what your heater says? That may help.
    Essential Links:
    Mar 2011
    441
    Do you have a UV system or another item with a Ballast near the easy touch? If you will need to put a capacitor on the connections for the temperature sensor. I can't remember the exact MFD, but tech support should be able to tell you.
    20X40 30,000 gallon gunite pool
