Thread: Opening Inground Pool - CYA Level Low
    Sastocky's Avatar
    Mar 2013
    Jackson, Ohio
    22
    I am opening my pool today, *YAY!*, and tested CYA at <10. CYA was in range when closed.
    Does the CYA stay fairly homogeneous or do I need to circulate for a while prior to testing?
    Basically...start adding CYA or let circulate and retest tomorrow?
    Southern Ohio, 18'x36', 8'x3' deep, Vinyl, Hayward 1hp Super Pump, Hayward Sand Filter, Hayward AquaRite 25k SWG, 5-3'x8' Solar Panels, Hayward AquaSolar, Aqua Pro 137k Heat Pump
    Taylor K-2006, Taylor K-1766, Taylor SpeedStir, hth 6-Way with OTO
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Opening Inground Pool - CYA Level Low
    Circulate, then retest.
    Rule of thumb: always let the water mix about an hour before testing.
    Sastocky's Avatar
    Mar 2013
    Jackson, Ohio
    22
    It mixed for 2 hours prior to testing.
    pH 8.0
    FC 0
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by Sastocky View Post
    pH 8.0
    FC 0
    Then it's pretty easy to get things straightened out.
    1) Add acid to lower pH to 7.4ish.
    2) Add CYA granules to raise CYA to 30ish. You can do this immediately after adding acid. Pay attention to the methods described in Recommended Pool Chemicals.
    3) Half an hour after adding the acid, add the bleach you want. If the water is clear and the current CYA is 10ish, target 3FC. If it's green, target 10. Once some of that CYA dissolves, target 12. But that's all covered in the SLAM article.
    4) When you have clear water and the CYA you added has had a week to dissolve, recheck CYA and raise it some more if necessary. You'll need to raise you target FC then, too.
    Sastocky's Avatar
    Mar 2013
    Jackson, Ohio
    22
    Just read your reply but had already completed similar steps.
    I was just curious if the CYA settles out or stays homogeneous.
    I'm very surprised if it is this low as I do not drain my pool at all before winterizing, but I do have to pump quite a bit out when starting up. I've never had it drop that low.
    Sastocky's Avatar
    Mar 2013
    Jackson, Ohio
    22
    Thanks for the advice! I'm amazed how many people you all help on here. Truly amazing.
