Thread: Is this Calcium Scaling?
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    I never had any problems in the 7-years of moving into this home with this pool. Last spring we had it re-plastered and through the winter I had a bigger problem with hi pH that ever. After taking the cover off I saw this when adding chems but just thought is was a dirt like powder that I have seen before but trying to clean it and its hard. Just looks and feels like hard sand. It's on shallow water mostly like the steps and seats
    I would like to get some feedback before I start my own course of treatment but thinking a no drain acid wash maybe, maybe some ScaleTec too. Any thought of just going low on pH for a couple of weeks?
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Re: Is this Calcium Scaling?
    I should have added my numbers
    pH 0s 7.5 but several times during the winter it crept to 8
    TA 80 but had to raise it from 50 this winter - all last season constant 80
    CA is 230 but I am afraid to add if this is calcium scaling
    CYA is 40
    Borates are 40
    FC target is 5 and when I add daily bleach it is 2-3
    Polaris 280 robot
    Pool Calc user
    While I can't say for certain, that does not really look like calcium scaling.
    Does brushing affect it at all?
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Quote Originally Posted by JasonLion View Post
    Brushing does not affect it at all. I have even tried a new stainless steel hand brush. Where there are the blue diamond tiles I see specs that are on there and I can rub the specs off but not on the plaster. I have not tried a pumice stone. There is one step that is 5 or 6" deep and I slowly poured muriatic acid there before the filter came on to see if there would be a fizz and there was not.
    Polaris 280 robot
    Pool Calc user
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Any more thoughts or suggestions
    Polaris 280 robot
    Pool Calc user
