Thread: Wireless or wired Thermostat?
    Apr 2015
    Davenport
    30
    Hi All
    Can someone help me please, I have been looking for a while now for a reliable way to read my pool temp from inside the house, like those weather station type hang on the wall gizmo's, I have had all the floaty ones but they don't seem to last very long and it would be cool to just keep an eye on it so I know when my solar has got it to temp.
    I don't want to go buy a automation system as I don't really have anything else to automate, its either on or off, I have no problem having a wired system to check the temp with a thermistor on the end in the pipework or something along those lines. I installed my Hayward VS pump control inside the house hoping that would have a temp reading on it but it doesn't appear so.
    Hope someone can help
    Thank you
    Stuart
    Re: Wireless or wired Thermostat?
    A quick Amazon search turns up several possibilities.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,494
    Welcome to TFP. I don't know anything much about your question. But, have seen several threads here on the subject. Just did a quick forum search (top right) and found a couple of recent threads discussing the subject. Good luck!
    http://www.troublefreepool.com/threa...erature-Sensor
    http://www.troublefreepool.com/threa...ure-monitoring
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I've only tried the Accu-Rite model and had terrible luck with it. Eventually it flooded and was ruined, the second unit being a warranty replacement. It would be so simple to improve the design yet they don't for some reason.
    Essential Links:
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I have tried several wireless floating thermometers with not much success. All seem to leak after a while. The usual pattern is they work for a while but after changing the batteries once or a few times they start to leak.
    Then I found the Ambient Weather line about two years ago. Their floating sensor has a solar cell on it so the battery only powers it when it's not in the light. Two years now, I've had one in the spa and one in the pool. Haven't had to change the batteries yet. About the only problem is the wireless range won't make it from the pool with quite enough power to make it into the house, so I installed the readout so that it's just outside my window. Problem solved.
    I bought my system on Amazon.
    Here is a link to the Ambient web site if you want to research their products.
    http://www.ambientweather.com/flpospaandla.html
    chiefwej
