Results 1 to 9 of 9
Thread: Low CYA & SWG - what's my appropriate CH SLAM level?
    Jan 2015
    Fuquay Varina, NC
    22
    Opening the pool and starting the SLAM today. I've got a swamp this year - and the frogs that have moved in are in for a big surprise...
    The chart for CYA SLAM level with an SWG starts at 60. My CYA is in the 30's as far as I can tell. PH is 8+.
    Once I get the PH balanced - what is the appropriate amount of Chlorine with the CYA at 30? Would it be half as much as what's shown for a CYA of 60?
    I'm familiar with the process, and have a good test kit.
    16x32 in-ground vinyl liner, SGS Breeze 540 salt system, Pentair 1.5hp pump, Booster pump & Tagelus sand filter.
    Jun 2011
    Long Beach, CA
    2,790
    Re: Low CYA & SWG - what's my appropriate CH SLAM level?
    Following the shock level in the FC/CYA chart in my signature for a Non-SWG pool gives a FC level of 12.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    You are on the right track. Shock levels are the same, salt or no salt. Adjust the ph and get to work. Look out frogs! LOL
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    I'm not sure they are in for a surprise.....
    I have two frogs that visit every night during the summer. FC of 15 didn't even slow them down. I'm still trying to figure out how they get out of the pool. I kept scooping them out and taking them to the lake, but every night they were back....
    Sigh......
    Support the site
    Apr 2015
    Knoxville, TN
    64
    Good luck! The frogs don't seem to mind my salty FC of 8-10 either!
    Sand filter
    Salt Generator
    25000 gallon IG Vinyl
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Once you've completed the SLAM and passed the OCLT then you can add stabilizer to get back up to it's normal range (70-80) and fire up your SWCG.
    Solar Blanket, Well Water, Borax Added. 68
    Jan 2015
    Fuquay Varina, NC
    22
    Quote Originally Posted by ping View Post
    That's what I thought - I was a bit confused as to why there are 2 charts for SWG and non-Swg.
    Thanks!
    Jan 2015
    Fuquay Varina, NC
    22
    Quote Originally Posted by tim5055 View Post
    Sigh......
    LOL!
    We don't have much problem with debris, but frogs, toads, wolf spiders, and those oily beetles are a pain... There's a farm behind us and they have a pond. Once in a while I'll take them back there and set them free, but mostly they get flung over the fence.
    In spring I'll pull dead toads out of the skimmer almost daily. Can never get my daughter or wife interested in emptying the skimmer... the spiders and toads were one thing, but since the day I found a baby snake coiled up under the skimmer cover - they won't go anywhere near it..
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Same here and it's me A couple aren't that small.
    Have had snakes in there a few times and it makes me a bit cautious taking the cover off. I guide them out into the pool and net them to release back into the lawn as they help keep the voles away or at least at bay.
