Thread: TA is high, can I close and tackle it in Spring?
    Jul 2008
    Solon, Iowa
    170
    Here's where I'm at with closing for winter in the next 3 or so weeks:
    Ph 7.5
    FC 3
    TA 150
    TH 180
    CYA 40
    salt 3200
    Borates 50
    I'd like to get the TA down even though the Ph has been rock solid all summer at 7.5 (and yes, the stabilizer levels are a little low right now - lot's of rain recently). So, I started adding acid and aerating this weekend (hooked up a 50 foot 'soaker' or sprinkler hose to my air compressor set at 60 lbs, attached a weight and let 'er bubble - 1/2 of the pool looked like a cauldron in full boil!). After 6-8 hours of keeping the Ph around 7.2 by periodic testing and acid addition (I'm installing the deck surrounding the pool, so I'm right there anyway), the TA is just barely budging (14 and a half ;>) drops during titration). My question is, since my TA will go back up when I return the water level to mid-skimmer next spring (high alkalinity water source) should I bother now, and just tackle it in the spring??
    Kelly
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    30,403
    Re: TA is high, can I close and tackle it in Spring?
    Kelly,
    I think you're fine to leave it. I'm pretty sure there are several here on the forum (JohnT, up where you live) that simply live with T/A in that range year round.
    You don't post CH levels (that's fine unless they're outrageous) but, if your pH is as rock solid as you indicate, I'd not worry much about it.
    Guest
    You have new plaster that is curing. High calcium is not uncommon.
