Results 1 to 15 of 15
Thread: Help! Pollen or Mustard Algae???
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    We opened our pool for the season last weekend, water was so clear!. Ran pump for a few days with message to clean the cell on SWG. Cleaned the cell which started the full production of chlorine and then the next day the water appeared to have a yellowish/greenish tint from a distance, pretty much overnight. When looking closer it appears that the tint is only because of a film on the walls that appears to be pollen and/or dirt. It brushes away in a cloud. The water itself is still clear. I don't notice much buildup on the floor of the pool, primarily on the walls only. We have high pollen alerts in our area right now but the dusting on things outside is minimal compared to a few weeks ago before the cover came off the pool. Does this sound like mustard algae or just pollen buildup? I'm confused since it only seemed to happen AFTER the SWG was operating properly. Any suggestions are greatly appreciated!
    ​Jennifer
    19k gal, 27' x 54" AG Aqua Leader Saltwater 8000 installed April 2014; Aqua Pro 19" Sand Filter System 1.5-hp Pump; Hayward Aqua Trol Salt Chlorine Generator System; Overlap Boulder Swirl Liner; Polaris 65 Turbo Turtle Automatic Cleaner; TF-100 Testing Kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Help! Pollen or Mustard Algae???
    I'm not that far from you and I would say this time of year pollen. Increase the pump time and brush the pool.
    If your want confirmation, do an Overnight Chlorine Loss Test.
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    +1 for the Overnight Chlorine Loss Test. If you have algae, you will fail the test.
    Divin Dave,
    Pollen is very common this time of year. Pollen settles on the bottom of the pool with no preference for light/dark sides of the pool, and never on the walls. Mustard algae almost always starts on the more shaded side of the pool and usually appears on both the floor and the walls.
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    I only have the testing strips, which I'm hearing are not reliable. This is only our second year with the pool and had no problems at all last year, hence not having a reliable testing kit. I did test earlier this evening with the strips and the free chlorine level was almost nonexistent but I'm not sure that we've been running the SWG long enough to have much chlorine yet (and it rained pretty heavily today). I'm new to this so I'm hoping I don't sound too terribly "pool" illiterate. I will order a good kit tonight - what are your recommendations for the best one?
    ​Jennifer
    The best choice is the TF100 from TFTestKits.net. The Taylor K-2006 is also acceptable.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    The best kits are the TF100 and the Taylor K2006.
    Upfront, the K2006 is a few dollars less than the TF100. That means you will need refills more often.
    The TF100 is basically the K2006 on steroids. You can do lots more tests before its refill time. Its the best bang for the buck.
    The K2006 is available at several places online.
    the TF100 is only available at www.tftestkits.net and one other place on teh west coast, but I dont recall which website its on. *you can get the K2006 at tftestkits site too*
    teh TFtestkits site has a free shipping special going on right now if you buy x dollars worth of stuff.
    If you want to take advantage of hte free shipping, I would recommend perhaps getting teh Taylor K1766 Salt Test kit too. That salt test kit is very handy for us SW pool folks.
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    We all have to start somewhere. Here is some reading to help your pool literacy.
    Test Kit Comparison
    What we need to know to answer your questions
    Water Balance for SWCGs
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    Thanks you all, I'm about to order now. In the meantime until the test kit is delivered, should I just continue sweeping and vacuuming and maybe add something for an initial chlorine boost to see if that helps? I'm afraid that whatever this is may permanently stain my liner.
    ​Jennifer
    DFW, TX
    24,509
    Do you have any chlorine test at all? You definitely need to make sure your chlorine level is up around 6ppm. You can add bleach if you need to. Plain concentrated store brand bleach. No scents, easy pour or anything. We get Kroger brand 8.25% at grocery store.
    PoolMath can help you figure out how much of what to add to get desired levels.
    Nothing discussed here is capable of permanently staining your liner.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    What JasonLion says is right. If you have copper or iron in the water that could cause stains. Anything organic really isnt a problem.
    Divin Dave,
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    Update: we've been brushing the walls and floor daily and this method seems to be working. My guess now is that it was pollen buildup. No chlorine loss overnight and the levels are coming up to normal now (based on the testing strips) after continuous running of the SWG for a few days. I really appreciate everyone's input! Oh and I don't notice any staining so far, it's almost back to sparkling!
    ​Jennifer
    Jul 2014
    St. Simons Island, GA
    172
    It's comforting to see someone else having too much pollen. See the last several entries my thread in the forum "just getting started" called "pool start up march 2015 just for posterity's sake" (or something like that) for my pollen story.
    Home pool: Intex 11,400 gallon AG vinyl pool with sand filter & SWG. Taylor K-2006 test kit - coastal Georgia. I'm also in charge of the Elk's Lodge Pool, which is 55,000 gallons in-ground concrete with sand filter, 2 HP Hayward pump, currently using tri-chlor pucks and cal-hypo system.
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    Quote Originally Posted by Vince-1961 View Post
    Just finished reading your posts - We seem to have the exact same problem for sure. Good ole Georgia springtime! I agree that it's comforting to know I'm also not alone in this. I'm considering not even taking my cover off next year until the pollen is all gone!
    We've made a lot of progress just by brushing. I also read on another post that it's good to use a skimmer sock (or regular pantyhose) while sweeping to better catch the fine particles. However we've yet to try that and are still seeing good results. Good luck to you!
    ​Jennifer
