Thread: Need help repairing a Jandy valve actuator
    Apr 2015
    arlington, VA
    1
    Can you tell me where to buy the parts for the jandy valves? I'm having the same problem with mine but i think the gears need replacing. Thank you.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Need help repairing a Jandy valve actuator
    Here is a thread that might be helpful
    http://www.troublefreepool.com/threa...valve-actuator
    inyopools.com sells parts.
