Results 1 to 11 of 11
Thread: How to build plunger valve
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Hello everyone. I am upgrading our pool. We have upgraded equipment as seen in my signature. We are now upgrading our inlet and return holes to 1.5" fittings. So here is my question......
    Can anyon tell me step by step how to build a plunger valve using a ball valve? I have looked on here and read some threads, but really need and exact list of supplies including sizes to do it. We are not going to do a hard plumb of everything. We will still be using the 1.5" hoses and nuts.
    Any help is appreciated. Thanks
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Casey's Avatar
    SW PA
    10,446
    Re: How to build plunger valve
    Welcome!
    I can not help as I don't have an Intex but so many people tinker with them, someone will surely be around to give you info!
    Hope you enjoy the site!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Thank you Casey. I am already enjoying it.
    Lisa
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Anyone? I have searched high and low for plunger valves made by intex, but they don't even have them on their site.
    Lisa
    Jun 2013
    Seguin TX
    192
    You will need to do a search on Intex and then look through the articles.
    You can also check YouTube for some tutorials on how others hard plumbed thier pool.
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I showed my husband some of the threads about building your own plunger valave and I think he figured something out. I will keep everyone posted.
    Lisa
    Apr 2015
    Lagrange,Georgia
    1
    I'm really aggravated that I have this expensive ultra frame pool from Intex, yet I cannot find a plunger valve for it ! On their site they are listed as out of stock. ( over a year now ) It is a,$5.62 part price. Some sites are asking $81.00 & up. Very disappointed with Intex .
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by Susann View Post
    I agree. I searched everywhere and could not find any.
    Lisa
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    I changed my intex out to 1.5" hayward fittings. I didn't have to cut anything because my holes were actually bigger. I ended up needing bigger gaskets than what came with the hayward fittings. (I made my own with rubber gasket material from lowes. They're ugly but they work!)
    I didn't end up adding a ball valve on either side. Instead I bought the 1.5" return plugs that screw into the intake/return. It means I have to reach my arm into the pool to screw them in if I need to close it off...but that's fine with me. I just didn't want to add any more new plumbing connections outside the pool because I couldn't stand the thought of dealing with any leaks I caused.
    I should also add that I have a hayward pump and filter and the hoses that came with the setup. I just added a hose fitting on the outside of the intake and return and used regular hose clamps to attach the hoses. Someday I may switch to pvc...if I ever feel up to risking the fun of leak fixing again!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I know I am in the minority... I have NO VALVES on my AG pool. Its been this way for 10 years.
    I use one section of vacuum hose to "plug" the skimmer and if I disconnect the return hose, I either plug it or hold on to it with my hand, above the water level.
    My pluming is:
    Skimmer
    6 foot hose
    pump
    filter
    6 foot hose
    return fitting
    PoolSkim (inside pool)
    -- Guy --
    Jun 2015
    Wa
    1
    I just converted my summer escapes pool to use an intex sand filter. Had to buy extra parts already and would really like to avoid having to spend upwards of $100 for the two stupid plunger valves.
    Can you explain In detail how you "plug" the skimmer with the vacuum hose? I Just have the two hoses-one coming out of the pool into the filter, and the return hose going back into the pool. Do I need a third hose?
    Quote Originally Posted by techguy View Post
    My pluming is:
    Skimmer
    6 foot hose
    pump
    filter
    6 foot hose
    return fitting
