- Feb 6, 2015
- 6,179
- Plaster
- CircuPool RJ-45 Plus
I've been lurking around here for a couple months, after finding this wonderful site while researching something for my daughters pool. Decided to give your way a try and went through Pool School in an attempt to make caring for my own pool easier. Received my TF-100 and Speedstir on Wednesday. Finally able to test with it this morning.
Background - Drain and refill almost 2 weeks ago (last time was 3 1/2 years ago). This was after having CYA tested at pool store and also using an old Taylor K-2005 kit. CYA was 120+ in both tests. Also noticed several whitish growths in pool, which I assume were calcium scaling. In any case, drained, power washed waterline (lots of calcium build-up do to evaporation in AZ summers) and removed/power washed whitish growths, refilled. Added some granular CYA (in a sock) - targeted 30, at 25 now). Adjusted TC to 5+ and PH to 7.2 using a basic test kit I also have. Reduced TA a little. Put on solar bubble cover and tested water daily. Waited for the new TF-100 test kit to arrive.
Pool
FC - 7.0
CC - 0.5
PH - 7.4
CH - 300
TA - 110
CYA - 25
Fill Water
FC - 1.0
CC - 0
PH - 7.9
CH - 275
TA - 140
Water is nice and shiny. See my sig for pool spec's. I plan on using bleach for daily use - the Dek-clor and 3" trichlor tabs mainly for times I'm away for a day or more (previously used trichlor tabs exclusively).
I think I'm on track. Would like to get the CH down, but think I'm dreaming there as my fill water is high also. Is CYA high enough, given I will occasionally use trichlor? Any recommendations will be greatly appreciated.
Thanks - Gene
Pool
FC - 7.0
CC - 0.5
PH - 7.4
CH - 300
TA - 110
CYA - 25
Fill Water
FC - 1.0
CC - 0
PH - 7.9
CH - 275
TA - 140
Thanks - Gene
