Thread: Cya test with tf100
    Cya test with tf100
    I could still see the brown spot in my test tube and the tube was full. This mean I have zero cya or maybe 5 or 10. I was adding cya as maybe I had a reading of 10. THANKS for any HELP.
    20X40 IG,33,000 GAL,VINYL LINER,1 HP PUMP,HAYWARD SAND FILTER,CAMDEN,S.C.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Cya test with tf100
    How do you chlorinate your pool?
    Did you already add CYA? How much? Liquid or granular? It takes about a week for granular CYA to fully dissolve and register on the test.
    PoolMath, this will tell you how much CYA and everything else to add to your pool.
    38,475
    If the tube was completely clear, then the CYA would be near 0. But, if it was cloudy, then the CYA is just less than 30ppm and more than near 0.
    I would use PoolMath and add about 20ppm of CYA and then retest in a week.
    Orlando, FL
    690
    Is this a sticky on the forum? I sure could have used this information recently.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    DFW, TX
    24,509
    there is a link straight up there ^^^
