Results 1 to 8 of 8
Thread: A way to conserve reagent?
    Apr 2015
    Knoxville, TN
    64
    I'm on day nine of my pond to pool slam. My FC goal is 24, so I'm using a lot of reagent for testing. Is there a formula to dilute or use more than 10ml water to test FC so that I don't have to use around 50 drops per test?
    Thanks!
    Sand filter
    Salt Generator
    25000 gallon IG Vinyl
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: A way to conserve reagent?
    You want less sample, not more. I'm not a fan of FC dilution but it can do in a pinch. See the extended test kit directions in Pool School.
    Essential Links:
    It is possible to do the test with a 5 ml sample, where each drop of reagent counts as 1.0 ppm of chlorine. Getting the 5 ml correct becomes more important, as small errors in sample size become larger errors in readings than they would with a larger sample. Other than that, it works fairly well.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Essential Links:
    Apr 2015
    Knoxville, TN
    64
    thanks!
    Sand filter
    Salt Generator
    I've used a 1:1 ratio of pool/distilled (mixing 5mL of pool water and 5mL of distilled) to have a 1ppm FC precision as opposed to 0.5. I think the test is still pretty accurate. In theory you could mix 5mL of pool water and 15mL of distilled then take 10mL from that and have a 2ppm increment (I think). I'm not sure in regard to the accuracy though. If it reads 24, it may actually be 22, 26 or anywhere in between.
    14,000 Gal IG Pool/500 Gal Attached Spa
    Pentair Whisperflow 1hp Single Speed Pump
    Sta-Rite Posi-Flo PTM-135 Cartridge Filter
    Hayward H400 Natural Gas Heater
    Mar 2015
    Gilbert, AZ
    15
    You can pick up a 2oz bottle of R-0871 reagent on Amazon for around $9 plus shipping. That usually lasts me a while.
    PebbleTec | 25k Gallons | Purex Triton Whisperflo pump | Magnetek Century Centurion 1.5HP | Hayward Pro Series S311SX Sand Filter | Taylor K-2006 kit
    May 2014
    Clarksburg, WV
    331
    TF-100 XL Option
    Stock up on this. Plus it helps DaveS out.
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
