Thread: test
    Apr 2015
    Broken Arrow Oklahoma
    14
    test
    34000 gallon/vinyl/1 1/2 HP pump/ Hayward sand filter S310T/ Dolphin Deluxe4/ Circupool SI60/
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: test
    success! pic is pretty big, you could scale it down some.
    Apr 2015
    Houston Ohio
    148
    Re: test
    twestysy
    36k gallon in ground, Hayward 30in sand filter, 2hp Hayward pump, in-line chlorinator. Vinyl from Ohio.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: test
    test
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
