Become a TFP Supporter Pool School
Thread: freezing point of a SW pool
    Jul 2008
    Solon, Iowa
    170
    Does anyone know how 3000 ppm salt affects the freezing point of water? I'm guessing it will a little, but not enough to matter to a typical Iowa winter.
    Kelly
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    Mar 2007
    San Rafael, CA USA
    12,085
    Re: freezing point of a SW pool
    The amount of salt in an SWG pool has a negligible effect on the freezing point of water.
    The formula is that the freezing point depression for water, in Celsius, is 1.86 times the molality of dissolved substance. 3000 ppm salt in water is around 0.05 moles/liter which is essentially the same as molality (moles/kg) since the density doesn't change much. You double this concentration since sodium and chloride ions are separate so around 0.1 * 1.86 = 0.186C = 0.3F so not even one degree improvement.
    Richard
    Jul 2008
    Solon, Iowa
    170
    Thanks. That's less than I figured, and I was figuring small!
