Results 1 to 7 of 7
Thread: To Foam or Sand new install
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    So, I just came from lowes and they have Polystyrene Foam Board Insulation
    1/4 inch foam 4x50 foot for 45 dollars : 4 would be 180
    1/2 inch foam 4'x8' foot for 10 dollars : 20 would be 200
    3/4 inch foam 4x8 foot for 12 dollars : 20 would be 240
    DuPont Tyvek Tape to connect 0.167-ft x 164-ft 14 dollars x 4 rolls = 60 dollars
    Average for foam would be 260 dollars, is it better to go with the thicker foam?
    I can get 10 ton of sand delivered for 200
    I will be putting Aromor shield above both no matter which one I go with...
    Is the sand better to let the condensation out from under the pool?
    Have there been any mold or other issues with the foam that anyone has seen?
    I am liking the foam for not being able to wash out but is there a good reason to go with sand?? I am getting the foam cove so that will not be a factor..
    Opinions wanted..
    Re: To Foam or Sand new install
    Foam seems to be preferred in just about every way, but costs more. Sand is certainly tricker to work with during the initial install. It can also wash out later, causing problems. Sand is a little more forgiving of minor deviations from level, so you need to put a little more work into ground prep with foam.
    Jul 2013
    Fletcher, OK
    3,353
    hmmmmmmm,
    sounds like 3/8 fines compacted, then sand to level, then foam, then armor shield and foam coves......
    Ahhhhh, the perfect bottom
    Jun 2013
    Seguin TX
    192
    I would skip the sand, use crusher run as your base and to level all the poles. Then lay down the foam, tape the seams, tarp on top of that and setup the pool.
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    Jul 2013
    Fletcher, OK
    3,353
    Thanks Joe, I was wondering if the sand was really needed at all...
    Jun 2013
    Seguin TX
    192
    Quote Originally Posted by cowboycasey View Post
    This is what I did, I am sure some would still say to use sand, but it is your choice. I like the crusher and the feel of the foam under foot.
    Jul 2014
    Oakbank, Canada
    389
    I am redoing mine right now and will be using thin layer of sand, then 1" foam, then gorilla pad..........After 3 years of sand, I decided to tear it all up since voles were digging tunnels in it last year. I took the 4" of sand out, leveled out the ground again, and am installing blocks for the legs, then doing about 1/2" sand, 1" foam, and then the pad.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
