Results 1 to 14 of 14
Thread: Question
    Aug 2013
    Katy texas
    7
    Question
    First time to get algae in pool .it isn't bad mainly in deep end and on ledges. I followed the instruction
    On this site and got my FC up to 12 and checked it 4 times starting at 4 pm.each hour had FC loss of about 3-4. When I went to bed my FC was 12 and now this morning is a 12. Does this mean I am ok I can still see some green but maybe I didn't brush good enough.dont know if it matter but no sun today it looks like.
    22k,chlorine,cart,finished dec2013,pebble
    38,548
    Re: Question
    If you still see algae, then you fail the clear water criteria to stop the SLAM. Keep SLAMing and brushing.
    Casey's Avatar
    SW PA
    10,461
    Re: Question
    Agree with Jason. Brush the pool n SLAM.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    Re: Question
    Brush, brush, brush.....
    The algae may have a biofilm over it and brushing will berak it up allowing the chlorine to do its thing.
    Support the site
    Jun 2013
    Seguin TX
    192
    Re: Question
    Ditto.. keep the faith
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: Question
    You need to maintain the FC as best you can until you no longer see any sign of algae and your water test shows a CC of less than .5 and you pass the OCLT. If you were testing ever hour and losing 3-4 it doesn't make sense you went to bed and it suddenly stabilized. Just saying that doesn't sound right as the FC will drop a little less each time it's tested and adjusted back up. Going from dropping 3-4 in an hour to not dropping at all overnight just doesn't sound possible.
    You have only mastered one of the three steps necessary to insure it doesn't come back. Follow the directions for the SLAM and you'll have sparkling clear water in no time.
    SLAM - > http://www.troublefreepool.com/conte...tain-shockingl
    What test kit do you have ??
    Solar Blanket, Well Water, Borax Added. 76
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: Question
    How do you chlorinate your pool?
    What is your CYA level?
    Aug 2013
    Katy texas
    7
    Re: Question
    I use bleach and my cya is 30. I am getting frustrated because I brush 3 times a day but I still have areas that won't go away. Today I only lost 2 ppm over 6 hours but still can't get it gone.
    Also test kit is the recommended on this site.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Question
    Do you have poor water circulation in the areas with the visible algae? Can you post some pictures of the problem areas?
    Love TFP? Become a
    TFP Supporter!
    Aug 2013
    Katy texas
    7
    Re: Question
    I will post pic in morning. I have waterfall on different pump near area would running that help
    May 2014
    Franklin, NC
    9,216
    Re: Question
    Quote Originally Posted by rmyoung View Post
    I would like to give you a positive answer, but all I can say is maybe. It is not beyond the realm of posibility that the are I question does not circulate well without the additional pump. This would end up being an area With lower FC leading to algae. Not saying that is the case, but possible.
    Support the site
    Aug 2013
    Katy texas
    7
    Re: Question
    It could be because it the deepest part of the pool but it is closest to equipment.If it is poor circulation what do you do. Also turned n water fall which is about 5 ft from problem area
    Aug 2013
    Katy texas
    7
    Re: Question
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Re: Question
    If your brushing and it's not coming off have you checked for metals? Try dropping a vitamin C pill on the stain to see if it lights it up. Probably a good idea to post a complet set of test results.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
