Results 1 to 8 of 8
Thread: Why metal stains?
    Aug 2014
    Seminole, FL
    92
    Why metal stains?
    Had a couple of dime sized stains when I took over the pool. They disappeared when I got the pool balanced, keeping the pH around 7.5/7.6 July through October. I let the pH rise to 7.8/7.9 through the colder months with no stains.
    In the last couple of weeks I've dropped the pH back down to 7.5/7.6 as the temp has risen. In the last week about 30 small stains have appeared, mainly on the shallow end steps.
    That doesn't make sense! The only factor I can think of is that as about 6 weeks ago I raised CYA to 50 with 4 pucks dissolving over 3 weeks in a Rainbow feeder half open. FC remained consistent at 7, but pH dropped to 7.2 so I added pH up. Added way too much and had to add MA to bring it back down, all within a couple of hours. Stains have only appeared in the last week, and do appear to fade after MA addition.
    Why am I getting these stains at the lower pH? Am I heading for an AA treatment or should I drop pH to 7.2 for a few days and see what happens?
    Last nights test results:
    Temp 78
    FC 7.5 (after small Cl addition)
    PH 7.5
    TA 80
    CH 350
    CYA 50
    Mike
    Built 1980, 19' x 30' almost rectangular, screened 15,000 gal, plaster, Hayward DE 3620 filter (currently using cellulose), Emerson 1081 1HP pump, AquaCal Heatwave SuperQuiet SQ110R heater, Zodiac T5 Cleaner, Taylor K-2006 test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Why metal stains?
    Are you sure try are metal stains?
    Support the site
    Aug 2014
    Seminole, FL
    92
    Yes, checked with vitamin C tab.
    They are probably iron stains.
    Iron staining happens when PH is higher, when water temperatures are higher, and when FC levels are higher, or some combination of those three.
    AA will help remove existing stains, but to prevent the stains from reappearing you either need to remove the iron from the water (not always possible) or use sequestrant. Sequestrant will bind to the iron and prevent it from forming stains. However sequestrant breaks down slowly, so more needs to be added regularly.
    Aug 2014
    Seminole, FL
    92
    pH has been lowered from cold water values, FC always kept within correct CYA range. Seems to be iron spots in the surface of the plaster around the steps.
    Staying in the recommended ranges is not sufficient to prevent iron staining when there is iron in the water.
    I forgot to mention, the iron level in the water also effects the chances of iron staining.
    One more possibility, if the stains always show up in the same few spots they might be caused by iron inside the plaster that is too close to the surface. This would not apply if the stains are extensive or appear in different places each time.
    Mar 2007
    San Rafael, CA USA
    12,082
    The pH for water above the steps if they are shallow will be higher than the bulk pool water unless you've got continuous water flow over those steps. The reason is that carbon dioxide outgassing will raise the pH and in a shallow area with little water mixing the pH will stay high. Higher pH precipitates more metal stains.
    Aug 2014
    Seminole, FL
    92
    Sounds plausible. I just measured pH 1ft out and 2 down from the deep end (6ft) and right in the corner of the shallow end steps. 7.4 at both (I dropped it a little after last nights test). Pump hasn't been on for 3 hrs. I'll add my once every 2 days MA (about 5 oz) in front of the return jet opposite the steps at the shallow end to see if that helps.
