Thread: What to put under an above ground pool
    Apr 2015
    Belton/TX
    7
    Hi folks! My first post here and in response to what to put under pool. Just bought an Intex Ultra Frame, 22'x52" today. Do I put pavers under this type frame?
    Also, how far should I dig before leveling? Any directions would be appreciated.
    Apr 2015
    Belton/TX
    7
    Re: New Install - Intex Ultra Frame 32' x 16' x 52" AG Pool
    Am I understanding correctly? Whatever size of the Ultra Frame, cut the insulation board to liner size, then place pavers butted up to the liner size/insulation? (Newbie)
    Intex Ultra Frame 22'x52" round
    Casey's Avatar
    SW PA
    10,450
    Re: What to put under an above ground pool
    Welcome! You'll need patio pavers for each post to sit on. Select the area you want the pool and find the lowest spot and start leveling from there. The sod needs removed. This is the worst but most important part. I've done many by hand! It sucks!
    You can use that or sand.
    Apr 2015
    Belton/TX
    7
    Apr 2015
    Northport, FL
    11
    Do yourself a huge favor and rent a sod cutter if you can. I think it was $40 for 4 hours on a saturday and I finished the job within an hour. It also helps level the area while it cuts. Not very hard to run either.
