Results 1 to 8 of 8
Thread: Eyeballs
    Apr 2015
    Los Gatos, CA
    22
    Question Eyeballs
    Hi All,
    I have 2x returns in the pool, and one in the spa. They appear to be PVC pipe that was cut roughly to where the finished pebble surface would be. The pebble is covering the outsides of the pipe, and comes around the front of the pipe a little in some places. They are 1" Schedule 40 PVC.
    Both pool returns and the skimmer are in the deep end, and this is a kidney pool with the spa in the narrow part. I think it will be hard to get a good rotation of water flow going to make the skimmer work better, but I'd like to try.
    I can only get access to the inner diameter of the pipe, without chipping away pebbletec. This means I would need to either:
    A. try to find an eyeball that attaches to the inner diameter of a 1" pipe
    B. Use a little length of 3/4" pipe and glue it into the inner diameter of the 1" pipe (i would need to sand it a bit), and then attach an eyeball to that.
    Unfortunately, either of these will restrict the flow down to be more like a 3/4" pipe. I feel that 1" returns are already too small (and therefore too much flow restriction) for an efficient pumping system.
    Or I could consider:
    C. Try to get access to the OD of the pipe by removing some pebbletec around the pipe. I don't look forward to this.
    I also don't see a way I'm going to be able to do this without draining the pool below the returns -- Considering I'm in California drought country, I suspect I'm going to have to wait until the fall rainy season to feel ok about wasting that much water.
    Any great ideas?
    -Carl
    25000 Gallon Pebble pool/spa, Intelliflo VS, Pentair IC-40 SWG, DNS-60 DE Filter, Max-E-Therm 333k BTU heater, Polaris 280
    EasyTouch, ScreenLogic, Intellibrite
    Homemade AutoFill (1/2" Hudson Valve), 20-70 GPM flowmeter (Blue-White F-30200PR)
    Mar 2011
    441
    Re: Eyeballs
    20X40 30,000 gallon gunite pool
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Eyeballs
    You could find something that will glue into themselves you have to give you a threaded fitting for an eyeball I'm sure. The hole in mine it's much bigger than 3/4", so I'd say don't worry about the restriction at the actual eyeball. It will give you more velocity out of them.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Apr 2015
    Los Gatos, CA
    22
    Re: Eyeballs
    Thanks guys!
    Any experience with this? It seems crazy to think I could cement PVC underwater.
    http://www.homedepot.com/p/Oatey-Rai...8933/100342516
    oooh or this?
    http://www.poolsupplyunlimited.com/A...FdKIfgod24UAHQ
    -Carl
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Eyeballs
    I have zero experience or advice with waterproof pvc cement. I do know my pool equipment was done with the blue stuff. First time I'd ever seen it.
    Apr 2015
    DeBary FL
    8
    Re: Eyeballs
    Rain-R-Shine is not applicable underwater and will fail if you use it underwater. It does however work in moist conditions and will hold underwater after enough set time. All pool piping underground in Florida is required to use this type of cement, it's in the building code. Never used the epoxy you listed but could work as long as it's strength can withstand the head pressure the fittings will be under from the returning water.
    9,000 Gallon Lagoon, Zero-Entry Sunshelf, Natural Stone Weeping Wall & Coping, Deck Jets, Swim-up Bar Top, Wet-Ege Pearl Matrix Interior, Jandy Plus HP 1.5hp 2-Speed Primary Pump, Jandy Max HP 1hp Waterfeature Pump, Jandy CS250 Cartridge, Dual Colorlogic 4.0 Lights, PV3 Infloor Cleaning with MDX 3 Main Drain with Leaf Basket, Compool LX100 Controller, 5 Panel Fafco Solar Heat, Optimizer Plus.
    Re: Eyeballs
    The solution racket proposed is the best approach. There are friction fit return fittings that fit inside 1" pipe, and that really seems like the best solution.
    Apr 2015
    Los Gatos, CA
    22
    Re: Eyeballs
    I ordered some of the fittings that Racket suggested, and some of the epoxy. I'll update when I know more!
    -Carl
